Sentry's Turbo Build Thread Extravaganza!
Old 03-15-2009, 12:37 AM
  #476
elecblue06's Avatar
good **** yea.. vince was great working with me .. we had phone conversations to make sure things were going smooth and for quick response time.. sucks doing a first custom setup huh?
  #477
PsychoCam's Avatar
so did u go back to the stock fuel rail?
Old 03-15-2009, 12:45 AM
  #478
b_faulk75's Avatar
Nobody has ever doubted or blamed vince for this, he's great for the 2.2 guys. Sometimes Gm cant even figure out why they have weird programming issues, i swear i have seen bullitens that say, there has been a "programming anomaly" and our engineers are working to fix the prolem, lol.... Go Vince, get this thing going!
Old 03-15-2009, 12:47 AM
  #479
Sentry's Avatar
No, but I know that I can if necessary. I like having the new fuel rail, makes under the hood look much more interesting. Definitely a conversation starter, lol. Yep, elecs right, this is truly the first time anyone has ever gotten a tune for the intake manifold, also probably the first for the fuel rail swap. Vince has got a lot on his plate with my car, so there's bound to be some kinks that need to be worked out. He'll get it running.
Old 03-15-2009, 12:49 AM
  #480
elecblue06's Avatar
Originally Posted by b_faulk75
Nobody has ever doubted or blamed vince for this, he's great for the 2.2 guys. Sometimes Gm can even figure out why they have weird programming issues, i swear i have seen bullitens that say, there has been a "programming anomaly" and our engineers are working to fix the prolem, lol.... Go Vince, get this thing going!
prime example of gm oddities... cobalts use 2 clutch sensors logically.. so you press one sensor it triggers it in the ECM..
in the ion.. **** if anyone knows how the clutch sensors are triggered lol
Old 03-15-2009, 09:44 PM
  #481
Sentry's Avatar
Well, I just got off the phone with Vince. I feel embarrassed to say this, but it looks like I soldered my injectors harness backwards. :P That, and I think I've fouled the spark plugs by running it untuned. A very noobish turn of events on my part. I know the tune is good, because it's the same base tune that several other boosted 2.2's on here are running. Tomorrow when I get my car back to the house, we will do some investigating, and I'll get that wiring harness straightened out. I see no reason why it won't start then.
Old 03-15-2009, 09:46 PM
  #482
Jn2
Jn2's Avatar
wow that sucks, good thing im repin'n mine, no sodering at all,i emailed vince on how u gusy are areg oing down, apperantly everyone, for the lack of better words, fucked up during their build lol
Old 03-16-2009, 01:12 AM
  #483
Sentry's Avatar
Here's a wiring diagram for a 2005 cobalt 2.2. Hopefully not no one makes the same mistake as I did.
BTW, that first injector is TN, which I assume means tan.
Old 03-16-2009, 03:22 AM
  #484
Jn2
Jn2's Avatar
Yeah sucks, get'r done
Old 03-16-2009, 03:31 AM
  #485
elecblue06's Avatar
damn that blows man.. but i hope thats all it is... lol
honestly though.. better this way then the tune . IMO that is lol long as you didn't fry anything could be worse
Old 03-16-2009, 09:18 AM
  #486
Sentry's Avatar
Nope, I just fouled all the plugs and the wiring is backwards. Me and Vince were talking about the injectors wire colors, and when he said that green was #2, I instantly knew I messed up big time. If those aren't exact it throws off the timing completely. You get fuel at all the wrong times.
Old 03-16-2009, 10:05 AM
  #487
b_faulk75's Avatar
ok, it won't let me copy and paste the schematic, but #1= Tan #2= Light green/Black #3=Pink/ Black and #4= Light Blue/ Black
, all others sides are pink, they changed wiring colors fromk 05 to 07, good luck man....
Old 03-16-2009, 10:09 AM
  #488
Sentry's Avatar
Well, I have an 07. I posted the schematic for an 05, and they are exactly as you said.
Unless they are in reverse order, all my colors are the same as the 05.
Old 03-16-2009, 10:42 AM
  #489
b_faulk75's Avatar
The colors i posted are for an 07, that should be correct! The colors you posted are for and 05
Old 03-16-2009, 11:26 AM
  #490
Sentry's Avatar
Yep, looks like they didn't change, because that's what the 05 is too. I can't wait to get home and try it. I should just be able to flip the harness around and it should work. Gotta get some spark plugs, as mine are all fouled up I'm sure. Cross your fingers.
Old 03-16-2009, 11:59 AM
  #491
b_faulk75's Avatar
Fingers been crossed,lol... the wire colors did change, the one's i posted are your wire colors, the one's you posted are the wire colors for the 05.
Old 03-16-2009, 12:25 PM
  #492
FASTL61's Avatar
fingers and toes crossed.I wanna see this thing running
Old 03-17-2009, 12:45 AM
  #493
Sentry's Avatar
I just started working on the car, took out the gas drenched plugs and replaced those. Also, I found out that my injector harness was on backwards. It was literally flipped around, oh well. I'm loading the new tune now, and I'll know if it starts in a second.
But, now when I turn the ignition to the on position, I hear this loud *clank* noise. I can turn it off, and clak, then on, clak! It's pretty loud, way louder than I've ever heard it. I think it may be the fuel pump activating, but damn is it supposed to be that loud? Could I have messed up the fuel pump?
Old 03-17-2009, 12:54 AM
  #494
Jn2
Jn2's Avatar
wow on thing leads to another...ive started my car in my garage in the dead of night, never heard my fuel pump activate, than again it didnt ever not wanna start...hmmm
Old 03-17-2009, 01:10 AM
  #495
PsychoCam's Avatar
holy crap man is the ides of march getting to you...talk about bad luck.
I know the fuel pump sometimes makes some noice but hardly noticable.
How is vince with the whole situation. Calm? I take it How long have u had the tuner lol
Old 03-17-2009, 01:17 AM
  #496
elecblue06's Avatar
damn mang.. it could be the fuel pump... but IDK without hearing it .. i remember when i loaded the tune for boost and put it into the on position i didn't expect it to be that loud
Old 03-17-2009, 01:35 AM
  #497
Sentry's Avatar
Maybe I'm just paranoid. When I loaded the tune, it was a little off because he was adjusting it for when I had the injector harness swapped. So, I loaded the stock tune and the beast runs! I can actually throttle it to keep it running and everything, no dying!
I'm really excited, this is the first time I've kept it running since I disasembled. Flipping the harness over is what was wrong. I datalogged a good minute of it running on the stock tune, now Vince just has to take that and adjust his tune to that, and tune for the 42s and we'll have a running car!!!!
I had to quit running the car because in the garage it got really smokey, and yes I know about exhaust fumes, I was just too ******* excited that my car runs to give a damn. I'll smell that **** all day, haha.
Old 03-17-2009, 01:43 AM
  #498
PsychoCam's Avatar
Congrats Man. . . Vids Asap
Old 03-17-2009, 01:47 AM
  #499
Sentry's Avatar
As soon as we get the tune stabilized, I'll get a vid. Right now I've got a major exhaust leak that sounds horrible, I should be getting the correct sized studs and nuts tomorrow to fix that. I did hear the turbo spool for the first time today. Very very proud of that.
I can't get too crazy with the revving though, I once pushed it over 3k and heard it whistle at me, and I was like, oh ****! I better stop jacking with it before it goes boom. Stock tune FTL.
Vince just responded, at 12:49 AM. That guy is always up, he's going to review the logs tomorrow morning!
Old 03-17-2009, 01:50 AM
  #500
bikeboyben14's Avatar
congrats man its been a long time coming, enjoy it
Quick Reply: Sentry's Turbo Build Thread Extravaganza!
