Sentry's Turbo Build Thread Extravaganza!
#478
Nobody has ever doubted or blamed vince for this, he's great for the 2.2 guys. Sometimes Gm cant even figure out why they have weird programming issues, i swear i have seen bullitens that say, there has been a "programming anomaly" and our engineers are working to fix the prolem, lol.... Go Vince, get this thing going!
#479
No, but I know that I can if necessary. I like having the new fuel rail, makes under the hood look much more interesting. Definitely a conversation starter, lol. Yep, elecs right, this is truly the first time anyone has ever gotten a tune for the intake manifold, also probably the first for the fuel rail swap. Vince has got a lot on his plate with my car, so there's bound to be some kinks that need to be worked out. He'll get it running.
#480
Nobody has ever doubted or blamed vince for this, he's great for the 2.2 guys. Sometimes Gm can even figure out why they have weird programming issues, i swear i have seen bullitens that say, there has been a "programming anomaly" and our engineers are working to fix the prolem, lol.... Go Vince, get this thing going!
in the ion.. **** if anyone knows how the clutch sensors are triggered lol
#481
Well, I just got off the phone with Vince. I feel embarrassed to say this, but it looks like I soldered my injectors harness backwards. :P That, and I think I've fouled the spark plugs by running it untuned. A very noobish turn of events on my part. I know the tune is good, because it's the same base tune that several other boosted 2.2's on here are running. Tomorrow when I get my car back to the house, we will do some investigating, and I'll get that wiring harness straightened out. I see no reason why it won't start then.
#483
Here's a wiring diagram for a 2005 cobalt 2.2. Hopefully not no one makes the same mistake as I did.
BTW, that first injector is TN, which I assume means tan.
#486
Nope, I just fouled all the plugs and the wiring is backwards. Me and Vince were talking about the injectors wire colors, and when he said that green was #2, I instantly knew I messed up big time. If those aren't exact it throws off the timing completely. You get fuel at all the wrong times.
#487
ok, it won't let me copy and paste the schematic, but #1= Tan #2= Light green/Black #3=Pink/ Black and #4= Light Blue/ Black
, all others sides are pink, they changed wiring colors fromk 05 to 07, good luck man....
#488
Unless they are in reverse order, all my colors are the same as the 05.
#490
Yep, looks like they didn't change, because that's what the 05 is too. I can't wait to get home and try it. I should just be able to flip the harness around and it should work. Gotta get some spark plugs, as mine are all fouled up I'm sure. Cross your fingers.
#491
Fingers been crossed,lol... the wire colors did change, the one's i posted are your wire colors, the one's you posted are the wire colors for the 05.
#493
I just started working on the car, took out the gas drenched plugs and replaced those. Also, I found out that my injector harness was on backwards. It was literally flipped around, oh well. I'm loading the new tune now, and I'll know if it starts in a second.
But, now when I turn the ignition to the on position, I hear this loud *clank* noise. I can turn it off, and clak, then on, clak! It's pretty loud, way louder than I've ever heard it. I think it may be the fuel pump activating, but damn is it supposed to be that loud? Could I have messed up the fuel pump?
#495
holy crap man is the ides of march getting to you...talk about bad luck.
I know the fuel pump sometimes makes some noice but hardly noticable.
How is vince with the whole situation. Calm? I take it How long have u had the tuner lol
#497
Maybe I'm just paranoid. When I loaded the tune, it was a little off because he was adjusting it for when I had the injector harness swapped. So, I loaded the stock tune and the beast runs! I can actually throttle it to keep it running and everything, no dying!
I'm really excited, this is the first time I've kept it running since I disasembled. Flipping the harness over is what was wrong. I datalogged a good minute of it running on the stock tune, now Vince just has to take that and adjust his tune to that, and tune for the 42s and we'll have a running car!!!!
I had to quit running the car because in the garage it got really smokey, and yes I know about exhaust fumes, I was just too ******* excited that my car runs to give a damn. I'll smell that **** all day, haha.
#499
As soon as we get the tune stabilized, I'll get a vid. Right now I've got a major exhaust leak that sounds horrible, I should be getting the correct sized studs and nuts tomorrow to fix that. I did hear the turbo spool for the first time today. Very very proud of that.
I can't get too crazy with the revving though, I once pushed it over 3k and heard it whistle at me, and I was like, oh ****! I better stop jacking with it before it goes boom. Stock tune FTL.
Vince just responded, at 12:49 AM. That guy is always up, he's going to review the logs tomorrow morning!
