Sentry's Turbo Build Thread Extravaganza!
#103
You have to remember pink is always going to be the ground, and the other it going to be the live wire no matter the colors.
Awesome man, can't wait to hear that spool. It will have to wait til monday though, . I wish I could weld.
#107
Right now I'm in the middle of dropping the oil pan, what a bitch!
I got that sealant from autozone, as well as some fittings for the oil lines and for the intake mani vacuums.
#109
actually theres a high temp rtv that is orange...works alot better than the grey...especially made for turbo charged engines with higher temps..
#110
hmm ic I'll see which ones are available, I'm too busy trying to getmy car running again, my lower rad hose tee busted to I've lost all my coolant twice now, and it dripping the third as I type this I did a ghetto fix until Vulcan makes me a replacement aluminum one, no auto store had it, not even the dealer, no local junkyards carry new cars(02+) so I'm screwed till than, I'm reffilling it ever morning only to refill it again the next day, suck my ghetto fix is only temp till I get a permanent replacement here
Oh sentry post pics of ur oil pan, and use some etc in the treads for the drain fitting to avoid leaking
#111
I'll finish up tomorrow, some of those bolts are directly above the frame, no room to even get a wrench in. I'll probably have to cut some of the plastic in order to slide a wrench back there. Fun stuff.
#114
I'm trying to unscrew the oil supply boss from the block, but damn it's on there good. Having an automatic doesn't help at all either, transmission is always in the damn way. I guess I need a longer set of allen keys. Just venting that's all.
#119
Well, I would post "moar" pics, but I'm still stumped trying to figure out how to get this plug out.
Sounds silly I know, but I've wasted nearly all day messing with it. I'm totally lost for words, it will NOT come out!
I've tried a 7mm, but it is too big, 6 mm spins when I try, and I'm quickly stripping it. Any suggestions?
Here's some pics while I sort this mess out.
#120
I see on the manifold you have map sensor, brake booster, then what are the other 2 vac lines going to... please explain need info for my turbo build lol
also I used chanel locks when I took my galley plugs off my engine last summer. Just get a nice grip on the endge of the hex bolt and lock the pliars tight. One quick twist should nock it loose. ya 6mm is too small and 7 mm is too big I have had the same problem
#121
Please don't make me bust out the easy outs.
#122
well i used the pliars taht lock when tight up lol might be ficgrips or chanel locks I am not sure what they are called. i used the small pair i have got it to lock on the end of the bolt and used like a cheater bar over the handle end of the pliars and slowley losened it up.
#123
And btw, the other two lines are to my bov and then my boost T, where I'll hook up the gauge and in the future, my boost controller.
Damn you people make this sound so simple, .
#125
Passenger side or driver side? I'm auto, so there's this huge support bar in the way of the other two plugs.
That vice lock trick might work, it looks like there's just enough room to grip the outsides of it.
I'm at work right now, gotta wait til I get home to try it.
