Shaking at mid-high speed
Old 10-12-2008, 09:47 PM
VRCobalt's Avatar
Im posting this in the tech thread since I dont know if this is a braking prob or not.
Recently I got new tires, rotors, pads and shoes. After everything was installed the car drove smooth until I hopped on the interstate. When braking from 55+mph, the steering wheel shakes as if the rotors were warped. Tires were balanced, so I thought the rotors were warpped from factory. Advance got me replacements and I took them to a brake shop, and they said they werent warped. So i installed them, then hopped on the interstate again and same bs and it shakes bad.
Anyone got any idea what it could be, im taking the car to the dealer tomorrow since it has 500 miles left b4 warranty is done. Tires and brakes are good. Everything is smooth sailing when driving in the city.
Thanks for any advice
Old 10-12-2008, 10:13 PM
tru2nrtt777's Avatar
Hmmm, I have been staring at my screen for about 10 min and I have no clue why it would shake like that.
Old 10-12-2008, 10:33 PM
VRCobalt's Avatar
Chevy's mechanic will prob do the same except stare at the motor.
Maybe it's the axle or cv joints or hub. IDK, hopefully dealer will figure it out.
Old 10-12-2008, 10:36 PM
I'm too JDM for you
BLAZIN07SS's Avatar
so its only under braking? not under acceleration at those speeds right?
Old 10-12-2008, 10:38 PM
NWAE Cobalt's Avatar
haha
when you installed them did you get them seated on the hub correctly?? cause they have a little play
best idea is to have someone stand on the break pedal once you get the caliper and rotor on then put on the tire while they do that and tighten her down...that way it centers the way it will when you break hard...
good Q...my advise only stands under these conditions...
if not then something is wrong...WAY srong
Old 10-12-2008, 10:43 PM
It could indeed be axle, hub, ect. but it would be more under acceleration and engine braking in those cases.
Old 10-12-2008, 10:44 PM
I'm too JDM for you
BLAZIN07SS's Avatar
if it is only under braking then we can rule out drivetrain. possibly a wheel bearing starting to go bad?
Old 10-12-2008, 10:45 PM
Red07SSNA's Avatar
Basics....did you torque the wheel lug nuts to 100 lb ft in the proper pattern? If you are not properly torquing the lug nuts that can cause the problem you are describing. When you take the rotors off and have them checked they are fine but then you install the wheel and "wrench" the lug nuts down that will warp them....just my .02
Old 10-12-2008, 10:53 PM
o3nisoaso3's Avatar
maybe your **** was aligned bad. my gf's dad works at a body shop, fixed a car with front end damage n then sent it out for alignment (when b4 it was fine, sent out to make sure) got the car back n steering wheel was cocked to the side n **** wasnt aligned n it shook til he took it back n got it fixed... maybe a possibility in your case but idk
VRCobalt's Avatar
Yes, it's only under braking.
I cleaned the hub real good, no rust or anything. I also put the speed clips back on.
I tightened the nuts in the right sequence, how much is 100 lb ft. I used the bar that comes with the jack and tightened the lugs with downward body force.
Old 10-12-2008, 10:56 PM
JimzSS's Avatar
what are the speed clips you are refering to?
Old 10-12-2008, 11:00 PM
the little push on clip things that hold it *cough* roughly *cough* in the center of the each stud so that your brake is centered...they dont always work if you dont have the rotor centered first...
Old 10-12-2008, 11:01 PM
Red07SSNA's Avatar
When you take the car in have them torque the lug nuts with a torque wrench and check the ride again. 100 lb ft is a LOT for a lug nut .... most cars I've torqued are usually 60 lb ft.
Old 10-12-2008, 11:06 PM
for me (a large guy...i wiegh about 270)...its a "2 grunt" job...go till you push so hard you grunt once...then again...then its good
just make sure you are ballancing it on the center and not just prying down...that can creat alot of sheer force and break things...
Old 10-12-2008, 11:13 PM
VRCobalt's Avatar
Hope your right.
Im 270 also, and do what you just said. Im just gonna buy an air compressor and impact gun. Will prob make things easlier in the future. Esp. since Im gonna change the struts shocks and springs myself.
Old 10-12-2008, 11:15 PM
its supposed to be 100lbs
Hope your right.
be VERY carefull not to crossthread and shear things off!!!!
those guns can pack a HUGE punch of power in them...they can shear the stud off before you know it
they are GREAT for taking things off...beware when tightening down...i use an impact to get it threaded then i use a torque to tighten...overtightening can be BAD
Old 10-12-2008, 11:18 PM
Red07SSNA's Avatar
Torque Wrench FTW!!!!!!!!!
Old 10-12-2008, 11:20 PM
YES!!!!
Old 10-12-2008, 11:21 PM
VRCobalt's Avatar
This is gonna sound stupid, but what does FTW stand for?
Old 10-12-2008, 11:22 PM
Red2.4SS's Avatar
I just installed my winters and torqued each in sequence to 100ft/lbs!
If you do not torque properly it can cause the rotors to warp slightly.
For The Win!
Old 10-12-2008, 11:23 PM
For The Win!
w3rd...
blake...give me your turbo and your other rims...
Old 10-12-2008, 11:24 PM
VRCobalt's Avatar
Will under torqueing the lugs warp the rotors also?
Old 10-12-2008, 11:26 PM
Red2.4SS's Avatar
w3rd...
I like my rims. But may not reinstall the 18's again? not sure...
Keeping the turbo though!
And BTW get a torque wrench before doing any more car projects!
That can cause the wheel lugs to come loose!
Differences in torque between lugs cause warping and without a torque wrench they are most likely not the same.
Old 10-12-2008, 11:27 PM
Red07SSNA's Avatar
Without torquing the wheels properly you can affect the shape of the rotor -- it's more about uniformity.
Not stupid at all -- I still don't know what QFT stands for...anybody?
Old 10-12-2008, 11:28 PM
Red2.4SS's Avatar
QFT = Quoted For Truth
Quick Reply: Shaking at mid-high speed
