short ram help
short ram help
hey guys i was wanting to remove my airbox assembly and just put a filter there like a short ram but was running into some problems any advice on how to do that easily would be appreciated thank u
well primarly i hate to say but i havent even started yet all i want to do is attach a simple rounded filter like off of a cai or somthing but im kind of puzzled on how to do that to free up the air flow i had one on my old car to and also like the way it sounded so i guess any help in the terms of advice from start to finish would help lol thank u
Check this thread and see if thats basically what you want to do. I cant vouch for it as I only have the base model, but I think this is what your after.
https://www.cobaltss.net/forums/show...ht=Air+box+mod
ok cool thank u i think though that the base and the ls model are the same engine just a little different body and wheels its the ss thats completely different thank u agian though
thank u all again i looked at the pictures and specs on how to do that it is on a ss which the enigne is a little different if anyone has experimented or would know how to do this on a ls i would appreciate i do appreciate the link but i may need to see the same type of link with an ls unfortunatly
Dude, I cut my filter box off right above the sensor, shaved it down a bit and attched a e-1009 k&n filter and BAM!, CAI! Sounds just like the clips from all the prototype cai's . saved $250 in the process too.
I would personally find an intake off the same kind of car, but maybe a wrecked one or seemthing, and get it cheap/free and expirement, that way you still have your's in case you mess something up, you're not out anything
I custom made a filter mount for my girl's 2.2L Isuzu Amigo. It's not that hard... I ordered a piece of metal tubing with a 90 degree bend, some hose clamps, rubber connectors and a K&N cone filter. To make it fit I just took a hacksaw and dremmel tool to the stock air box. Cut openings on the sides and front to allow for increased air flow. The box holds the filter great. From what I can tell she got about 5hp off of the conversion, but more importantly she's netted about 5MPG as well.
It looks like the stock pipe the filter is all the way in the wheel well. I will probably end up getting a aftermarket CAI eventually, till then this is the same godddamn thing.
SS_2009_TC
09-11-2015 05:41 PM
