Slight difference in DP
I have a 2008 2.2L Auto and was going to do the LSJ header and DP but came up with Header is fine but the DP is quite a bit shorter and when I pulled them together the tailpipe was under the vehicle and the DP rests on the swaybar. I put the header in and put the stock DP back on just used a broken O2 sensor to plug it until I get a different DP or just put a plug in. Here is a pic of the difference.
Check out my thread on the LSJ DP on my auto equipped SS/NA/2.4
https://www.cobaltss.net/forums/2-4l-le5-performance-tech-46/2-4l-auto-dp-vs-lsj-dp-150651/
NO the other way around I have the manifold on with out the DP for automatics. Manuals the whole thing Header and DP together fits. LSJ header has bung and Downpipe has a bung thats the two you need.
Thanks for the information. This has dramatically helped me in my project.
I am supercharging a 2009 G5 GT... but it has the SAI.. so I am installing a new header (to get rid of the SAI stuff) and downpipe when I install the SC and was trying to figure out what to buy.
I will have to add a bung of the wideband AF probably, but that is no big deal.
OP... I will buy your DP then if you want to get rid of it for a good price. Please PM or email.
importkiller
09-30-2015 07:18 PM
