So...building HHO (Hydrogen) Fuel Cell this weekend....
#76
Interesting video of fuel cell being made and working:
http://www.truveo.com/Do-It-Yourself.../id/1341555959
Site associated with video:
http://diyhydrogenhho.com/
#79
BWAHAHAHAHAHAHAHAHAHAHHAHAHAHAHA! this is bull ****, but im not going to explain it to you in "technical terms" because most of you won't understand and some of you will just cry and whine. Let me just explain why this is TOTAL BULL **** the easy way
-without a tune, even if this did work, your injectors would still be dumping the exact same amount of fuel in.
First of all don't be so uppity about saying something won't work when you have so many people saying it does. Your car shoots for a general AFR, using 0xygen sensors to pick up whats left over and adjust according to altitude for an optimum power production, your car picks up the fact that it is producing more power than the AFR should be supplying and backs down the fuel in an attempt to even it out, all its gonna do is drop the AFR down because your getting more air explosive now and so you require less gasoline explosive....See they build cars smarter now so they auto-tune themselves, get your head out of the stone-age.....
Then explain this to me. How is it that timing and everything auto adjusts to altitude and gas grade you are running? Is that because the car can sense the explosive force and the afr ratio to some degree?
Personally if this is proven safe and reliable I will get it. Without question. My worry is for cars with FI. If you try to let vapor be pulled into the motor by the motors vacuum and we are pressurizing that chamber wouldn't we in turn loose boost and power and potentially cause a hazardous situation?
It is proven safe and reliable as long as you have a couple safeguards against pressure buildups and stuff like that (i.e. pressure relief valves...stuff like that) As for pushing this gas(vapor typically involves bigger molecules that are not split, remember this is producing pure H2 gas and pure O1 gas. To be honest I'm not sure if you'd lose boost, Hydrogen is like 30 or 50 times lighter than oxygen, so in the end, you might lose boost, but if you bought a car with a supercharger/turbocharger on it, you weren't concerned with gas mileage anyways lol!!!!!!!!!! JK guys...
The risks are the same as everything else, however minimal, hydrogen needs an ignition source to ignite, and disperses 50 times faster than normal air, if your valves have a leak the flame could very well travel back through the intake and into the container where it would....................hit the water and extinguish itself lol.
I will post pics of the inside of my muffler after 1000 miles, supposedly it cleans out your car too...
As for the guy that said he loved "that post" about the chemistry behind it....I totally agree with that post 100%, if we wanted to burn 1 gallon of water in 1 HOUR!!!!!!!!!!! No, look at my calcs 1 page back from here and look what I said, simple math, all verifiable. Don't bash it unless you have proved I made a mistake lol.....
#80
Location: Home: Utica, MI Current Location: Mobile, Alabama
um..........wrong?
Yes the car auto adjusts its fuel trims for optimum power in all RPM ranges, its called an algorithm, kind of like your oil % meter. Except its based in flash memory, so when you unplug your battery, it resets the learned fuel trims to factory standard and starts to learn it all over again.
#81
BTW chief....I'm a mechanical engineer........I'm sure I would understand the "technical terms"... and could probably throw a couple your way....
Oh about the o2, I was under the impression when you broke down H20 it broke it down to H2 and O, my fopah lol........thats where the chemists come in handy lol......."meaning it doesn't exist as a single molecule"....you mean to say "meaning it doesn't exist as a single atom."
#82
Also think about this. At idle the car produces a certain voltage and amperage which the car does not use all of. The regulator sends the batter and ignition module what it needs and the rest is dissipated as heat through the battery. So instead of wasting this "extra" electricity, you send it through water to produce the 2H2 and the O2. This will displace some of the gasoline going into the cylinder, which gives you the better fuel mileage. You are correct in saying that it takes much much more energy than it produces because this is inefficient electrolosys, but we arent trying to run the entire car off hydrogen are we? We are just using the leftover energy from the alternator to do the job. This is similar to how hybrids work, when you apply the brakes instead of the brakes loosing all that energy through heat emmission, you are using a generator to reclaim that energy.
#83
why not just get a hydrogen tank and figure out injection? if u could throttle regulate it, in combo with a tune, i bet you could do something.
it's a sound concept. hyrdrolysis taking place in the car is not efficient enough, or else the honda fcx woulda come with it, instead it uses straight hydrogen.
#84
yeah...I'm bypassing that by putting into into the original cam cover breather hole in my CAI intake so not only does it have a place to release pressure buildup but it will also pull a good amount using the venturi principle too......like a carburetor pulling gas in............
#85
#86
yeah i'm a chickenshit when it comes to my vacuum line lol........and one plan I saw did that, had it both in the intake and in the vacuum line lol......
#87
Well I guess the magazine I work for it going to test this out by building a fairly large unit. I think in the 64 Oz range. And we are either going to test this out on a Solstice or my Mustang.
First we are going to build the kit, and then test it by running it through a bubbler. If it doesn't blow bubbles it doesn't make gas. So we will find out.
#88
um..........wrong?
for every 2 molecules of hydrogen you are putting in there you are also adding one molecule of oxygen. For any reasonable increase in energy form the combustion you are going to have considerably more oxygen.
people say the turbonator works too! and look they even have lab results!
#89
hmm that's interesting, so this extra o2 product is just disappearing? Your car will see the extra o2 as a product and add fuel.
#90
Yeah sorry about that, I was a littel fuzzy on the restructuring of atoms after electrolysis, I didn't know we didn't have monoatomic oxygen...my bad...
AS for the extra o2? no it'll ignite, just like the hydrogen, all it needs is the spark plug, a guy at my work brought up what you said cakeeater, that it'll dump more fuel in to balance out the more o2, but I was thinking about it and pulled out my manual....the way the engine reads o2 is it reads it through the MAF sensor which responds to o2 rate of flow over the platinum wire and tells the computer how much o2 is coming, and then tells the system how much fuel to dump in from the table and then the o2 is measured coming out the back. The way our and I assume the "99%" of other cars from the water4gas website is that the computers are programmed to to take the MAF measurement over o2 sensor in the exhaust.
Myself and that other guy are going to plug them into the breather hole which is after the MAF , so the engine doesn't know its getting the extra air. Remember the only thing that keeps the o2 in the atmosphere from lighting off is the nitrogen and miscellanious gasses in the air. Concentrated o2 and h2 are going to burn up almost completely along and better burn the natural air o2 in your car and your car is going to detect a lot less o2 coming out, think its coming in too rich and lowering the gas tables to accomodate the "acceptable unburned o2 level on exit 1 and 2"
#91
Everyone has to agree that this works in theory. There are lawnmowers that run on hydrogen from tanks.
The theory is sound.
http://www.hydrogenhighway.ca.gov/vehicles/ice.htm
It works, if you don't agree stfu, or start your own thread.
Last edited by GreenPurgatory; 06-05-2008 at 04:57 PM. Reason: Automerged Doublepost
#92
alrighty HOW TO will be published this weekend...I'm gonna be building it this friday AND i'll take plenty of pictures and even a video of it working...as well as putting about 200+/- miles on it this weekend to test it.
#93
That sounds good! I can't wait. We are peicing our ~64oz kit together this weekend, and we even ordered a 500gram supply of this higher grade catylist.
#95
Don't worry dude I will lol I don't plan on blowing myself up or electrifying myself.
As for the link included in that post....
I love how people forget to include the chosen catalyst in those wonderful brilliant moments of chemistry history lol....
See here's where all their naysayings come into play right here...
He said it takes 13.7kw/h to break down 1 gallon of water....
Ok so 13,700 w/h to break down 1 gallon of water - in 1 hour haha!!!!
but hold on lets look at this, in a cars electrical system which for the majority runs on 12v...
watts = volts * amps
13,700w/h = 12v * amps/hr
Amps = 1,141.67 amps to break down 1 Gallon in 1 HOUR!!! (i.e. the total amps to break down 1 gallon is not going to change, so it takes 570.835 amps for 2 hours and so on)
So lets say you run your car for 2 hours a day with 1 gallon of pure water, no catalyst, and on a 4amps of current.....so your putting 8amps a day into breaking down this water.
So according to the math using the standard of 1141.67amps means 1 gallon will take 142 days at 2 hours a day assuming you keep the wires totally submerged......
So lets drop that down to a mason jar, 1qt of water = 3425 w/h = 285 amps for total breakdown which means about 35 days of breakdown time
Now add a catalyst and total amps required drops down a little.
I love how chemistry ignores the electrical side of the equation and make huge numbers out of things that will never never happen...1 gallon in 1 hour? puhleeze....considering most houses have +/-400 AMP electrical panels powering their entire house. nothing but an industrial grade generator could produce the 1141 amps required to break down all the gallon in 1 hour.....
this website answers a lot of questions
http://www.hydrogenassociation.org/general/faqs.asp
Let's go with your numbers, burning one quart of water in 35 days, or at 2 hours per day, about 70 hours. We won't need the catalyst used for electrolysis or the amperage/voltage for this. It's been demonstrated it can be done at this rate with or without a catalyst by the alternator, all we're interested in is the rate and amount of Hydrogen available per unit time. I'll go over a 70-hour slow burn of the available Hydrogen, and a scenario in which we burn it all off in two hours, or even one hour.
Starting with the power extracted out of the Hydrogen-Oxygen reatcion (since the system claims to increase power along with mileage):
One quart of water has about 3.165 * 10^25 molecules in it. Double that to find the Hydrogen ions generated from electrolysis (6.33 x 10^25). That's about 105 moles of Hydrogen. The energy yield of the Hydrogen-Oxygen reaction is 286 kJ/mol, or about 30.07 MJ for the entire quart of water. Since we want the energy spread out over 70 hours, this comes to 430 kJ/hour, or about 0.16 horsepower.
This is primarily why I don't believe their power increase claim. 0.16 HP is a gain, but not noticeable, you can get more by replacing a bad air filter.
Next, let's look at the mileage increase. This is said to work by leaning out the air in the chamber with Hydrogen as a replacement, such that you've got less Oxygen and more Hydrogen. The MAF sees less Oxygen and compensates by squirting less fuel. This is seen with normal gasoline at altitude, where the MAF adjusts for less fuel to hit the commanded AFR.
For this part, we'll use the 105 moles of Hydrogen gas we've generated, and a few assumptions to try and maximize the gains. Assume that:
- We have a device to meter the hydrogen such that it is fed evenly to the engine over the entire 70 hour period.
- We are using a 2.2l Cobalt LS 5spd manual.
- Volumetric Efficiency is 90% (a good number for a N/A car)
- The car is traveling at a constant 60 MPH.
With these in mind, we can calculate:
- The amount of Hydrogen available per hour is 105 mol/70 hours = 1.5 moles, (about 33.15 liters, or 1.18 cubic feet)
- In fifth gear, at 60 MPH, the car is at 2590 RPM. (3.84:1 final drive, 0.81:1 5th gear ratio).
- At 90% VE, and 2590 RPM, the car needs 99 CFM of air (or about 2,803.37 liters/minute)
Expanding this to one hour, we get:
- 2,803.37 * 60 = 168,202.2 liters of air per hour
- 2,590 * 60 = 155,400 revolutions per hour
Per revolution of the engine, we get:
- 168,202.2 liters air per hour / 155,400 revs = 1.082 liters of air per revolution
- 33.15 liters Hydrogen per hour / 155,400 revs = .0002 liters of Hydrogen per revolution
If we're tuned for this extra Hydrogen, we can remove the same amount of air from the chamber. We've effectively reduced the amount of air, and leaned out the AFR by .02%
Burning the entire stock of Hydrogen in two hours only increases the power gain to 5.6 HP, and the air reduction in the chamber by 0.7%. Going to a one-hour burn increases the power to 11.2 HP, and the air reduction to 1.4%
This is why I don't believe the MPG increase claim.
OP, by all means test this out. Post the gains, post the engine pictures, post everything. I've said from the start I'll change my tune if it works, but right now the numbers don't add up.
#96
alrighty, I'm building the homemade one, the other guy is building a 64oz pro kit, we'll both post our results as long as we don't kill ourselves over the weekend....till then...see ya'll
#97
The Hydrogen has to have something to combust with, and Oxygen's its only option. Actually, compunds containing Oxygen are the only option for combustion with anything. Take the electrolyzed Oxygen out, and you have to combust the Hydrogen with the Oxygen pulled in from the outside air. This leaves less Oxygen for the fuel to combust with, resulting in a rich condition. The MAF would pull fuel to compensate for the unburned stuff in the exhaust (assuming there's enough of it to register on the MAF).
Of course, this would work if there was enough Hydrogen in the chamber to consume most of the Oxygen, but there isn't unless you compress it. Burning compressed Hydrogen has its own problems though (it would burn too hot for the gas engine). If you want to go that route, the Honda FCX is probably a better bet .
Putting Oxygen in after the MAF sensor on the intake will probably come out as a wash. The Hydrogen will consume it in the combustion reaction, rejoining with the Oxygen it was separated from, turning into water again, and the exhaust sensor will be none the wiser. I wonder what the water will do with that sensor though... hrm.
#98
the water probably won't do anything considering we won't be recombining enough o2 and H2, besides, when your exhaust hits 400 or 500 degrees...its not gonna matter, that waters gonna separate again..........
#99
We are building it from scratch too. I'm not paying $1,000 for a kit to test it out LOL!
