So...building HHO (Hydrogen) Fuel Cell this weekend....
#176
yeah last thing you want is the water to boil and spew steam into the engine... hmm not sure about the coating on the plates perhaps something isn't stainless and its corroding and placing the deposits but that would mean that one of your posts should be wearing away and the other should be gaining the others losses (dissimilar metals would cause this). I can't wait to get off work and start playing with this stuff lol
edit: a lot of people seem to add a bubbler chamber off of the HHO generator. this is basically another chamber where the tube goes into some more water and the HHO bubbles up through the water its a sealed chamber and another nipple with a hose is attached and then that goes to the intake (if that makes sense) this cools the gas as well as helps in the case of a backfire so that you don't blow up your generator
I used a water bottle for a bubbler but it wasn't producing enough to work. The generator wasn't sealed "professionally" either so that didn't help.
Anxious to see how the OP's turned out. It must be incredible since they have been working on it day and night for 4 days now!
#177
I've heard about this before. I believe the issue of why they are not on production cars is the fact that you are creating a canister containing pure Hydrogen underneath your hood. Last time I checked Hydrogen was a very explosive gas.
If you were to get into an accident and your hydrogen filled canister would explode I wonder what would happen?
When I initially looked into this, I found that it was illegal to do in my state.
#180
#181
Remember folks it's not a bomb, just a small jar of water with small amounts of hydrogen bubbling to the top. When you get in an accident if anything the generator will put OUT a fire
#182
If you have a line running to the front of your air intake, where the hydrogen is sucked in to be mixed with air and gas......isn't that almost the same as having a gasoline line running to you carb or fuel injectors??.... Why is this a BOMB??... If you had a leak though and the hydrogen gas pooled up under the hood, that could be bad I guess....
#184
Okay, this is officially some fun stuff! We just got done building our Hydrogen Generator. And HOLY CRAP this thing pumps out some "gas" This thing is out of this world.
WARNING: DO NOT TRY TO INTRODUCE THE PRODUCED GAS TO AN OPEN FLAME. This stuff doesn't burn like you would think, it makes the sounds of a string of blackcats!
I have video of our creation in the kitchen, but not yet hooked up to a motor. You can see how robust this generation is. It's not one of those stale jars of water like you thought, this stuff looks like a rolling boil! Waiting for Google to process the video so I can post the link.
We created a 128oz........twice as big as I originally planned. And we used very small electrodes to minimize the creation of gas, but you can add a lot of these electrodes and make this thing pump oiut even more volumes.
When you light this stuff it is SCARY LOUD.
We had massive success using Potassium Hydroxide in our water, and almost no reaction with plain water. Mix for potassium is 15grams per liter of water. You can get a jar about the size of a peanut butter jar for $13
You're right, let's just rush into this without getting proper time to test this and then evaluate results. And then we can tell you how to do it before knowing whether it actually works as well as we hope.
I bought 5 stainless steel light switch covers like I've seen on youtube videos but am still not getting the wild fizzing like theirs.
The plates are screwed together and have plastic spacers, with every other plate having a positive charge. The way this was done is when the positive screw passes thru a negative plate the hole in the plate has small piece of plastic tubing for insulation. Same for the negative screw passing thru a positive plate.
A teaspoon of salt and teaspoon of baking soda were added.
It did work, just not as well as I expected. Back to the drawing board.
#186
And here's a link to our test to make sure that the kit produces gas:
http://video.google.com/videoplay?do...60314350956295
#187
check out hhoforums.com there are people there with finished and near finished setups! they are posting some real world numbers there and have reported good success with this
#189
http://www.mindstrain.com/
this guy has results as well as a video and a PDF (how to) for download on his site!
#190
Great article -> LINK
let the idoits be idiots. It doesnt matter what you say. They want to try it, spend their money, and fail (or have a placebo effect)
Basically, all this proves is that you and I are idiots for not producing and selling these kits eventhough we know they dont work. I have no problem taking money from the fool willing to throw it at me after i told him its junk.
#191
Tyler.. give it up
#192
Tyler.. give it up
#193
#194
Well, if I just sat here and took your word for it then I wouldn't learn anything.
And people in the cigarette industry did studies to prove that cigarettes didn't cause cancer, so I'll take their word for it to.
It's funny. I can't say whether you are right or wrong yet, but I just have to try it for myself. You have to understand that. If people were talking about how to build your own rocketship to go into space I'd be building one of those too to see if it worked.
#195
A. make the car add MORE fuel
B. Make the car run leaner and leaner the more hydorgen you are getting.
depending on how you set up the system. You are not going to see benefits from this guys.
#196
might as well just ignore it....nobody will listen. I suggest you guys use it in conjunction with twin turbonators.
It doesn't matter if they tried it before. look at the facts. How much water are these people using? You aren't getting enough hydrogen to make much of a difference, if any, and you are getting half as much oxygen, which is LITERALLY going to either
#197
Guys, you can't argue with a guy who wants to see for himself. It's not a waste of money to him, and he'll learn something either way. He'll come out the other side with something he didn't know before.
#198
#199
Go for it dude, you know my piece, I happen to agree with Omega_5, TVS_SS, and cakeeater, but that shouldn't stop you. Doesn't look like it is either
#200
As with many claims, they can be Proven/disproven through calculations and analysis before even making a single component to test
The problem here is that no advocate of this technology has the knowledge to do the calculation or so it seems..
Things like..
Air fuel ratio (mass/mass) what is it with HHO for a stochiometic burn?
Flame speeds (determines spark timing to get location of peak pressure at the desired angle) What affect would this have on peak cylinder pressures?
Octane or Anti-knock characteristics what is self ignition temperature?
volume- you can only fit so much gaseous fuel in a cylinder without displacing too much oxygen and eliminating the proper chemical reaction. What does this do to your AFR from the regular gasoline and air normally inducted?
Basically, once you start looking at it as a system.. there is alot to consider even beyond the basic chemical reaction.
would you believe me if i said EGR would give you better fuel economy than this HHO fuel?..
Things like..
