Solid Mounts and Cams FTMFL
Yeah its rough with just one. My dash vibrates so damn bad. It's annoying if you dont got music on
http://www.turbotechracing.com/produ...idproduct=5068
^ Those are the mounts i got.
Vibs are a side effect to soild mounts, it is what you want out of your car I guess. Performance vs stock...
Give the mounts at least 1000 miles before you make your call on them. Maybe you do have this many miles, but each person has diffent levels on how "the vibs are"
The trans mounts are the mounts that actually help the most . If anything , if u cant take it , go back to a stock motor mount and keep the trans mounts .
#36
#48
Hopefully it will reduce the vibrations because theres only 1 installed now. The car sounds different now also when i go up to like 4 grand and let off the gas it revs down slower then it shifts into the other gear like after 2 seconds.
