somethings wrong with the car ?
ok now i don't know if this happens to everybody but when i have the defroster on and i drive and i have it in first up to 2500rpm and i brake for example it goes under 1000rpm and does this sound as if would want to turn off. The funny this that when i turn the car its right below the 1000rpm line but when i drive in first when the defroster on and i brake it goes way under 1000rpm is that normal somebody please ?
anybody want to know if this is normal
yeah something like that but i wanted to know if that was normal or wat because that doesn't sounds too good, like when i start it up in the morning and i just tap on the gas right quick it does the same thing but today i was driving the car and i had the defroster on cause my window was foggy and then i noticed then when i would be in first gear and go back to neutral and brake it would do the same thing and it was lil bit weird so was wondering if that happened to you also.
so that must pull alot of power cause i thought something was wrong with my car thanx an0malous for the help just wanted to make sure i wasn't going crazy
NoBalt123
09-04-2015 07:10 AM
