Spanky's 2.2 Turbo Build....Stage 2
#104
i did stay stock because i don't plan on powering this bitch past 350 in it's present form. the lsj and l61 have the same sleeves but the l61's compression won't allow for the same high boost levels as found on the turbo lsj's. all said and done my engine will see the same power levels on less boost but would be just as stressed so i'm shooting for 280 as my current DD/weekend warrior.
#105
For sure though, the LSJ pump does send fuel at a higher rate of pressure than the L61, otherwise known as psi.
The LSJ and L61 also DO in fact use a different fuel filter to support this higher rate of fuel flow. It is a completely different part number.
^ As per the GM Build book. I own it for both cars.
#106
Great information, although, I stand my ground on the following..
For sure though, the LSJ pump does send fuel at a higher rate than the L61.
GM may make different part numbers for the filters (which I have no way to verify), however if you look at aftermarket solutions, the part number is the same for all of the Cobalt models (except LNF). I have the same filter on a 2.0 SC and a 2.2 and both cars run stellar. I have a BRFPS and a pump rewire with the same filter and my fuel system performs perfectly fine. What is different about the filter if the filter is different?
#107
Fixed it for you. Pumps cannot produce pressure on their own. You're cofusing flow and pressure. Two seperate principals in physics. A pump sucks in fluid and spits it back out, which does nothing to build pressure. Same as boost, pressure is a restriction.
I'm not sure what's different, I'm trying to see if they say anything in the build book, but all it says is that it's a different part number, and it is built accordingly, to support a higher rate of fuel flow.
#109
Exactly.
Shadow, not trying to cause a ruckus, but that's how it goes... Look up the specs for any fuel pump, and you will see they are spec'd in a l/hr or some other amount/time measurement.
Also I am genuinely interested in the different fuel filters, because if that is so, then I have a wrong part on one of my cars...
#111
Anyway I don't want to muddy up your build thread anymore than I already have. Keep up the sweet turbo build!
#112
Awesome I forgot about that, I'm going with this option, 4T40E | 4T45E | Transmission Rebuild Kit
Called and talked to the guys there and they said it could easily withstand 400WTRQ. Ill be installing it within a couple months. So I'll let you know how it goes
OK I'm sorry, but I'm going to correct the fuel pump misinformation in this thread...
First of all, pumps don't 'pump at a certain psi'. Pumps only flow liquid at certain flow rate usually measured at a certain l/hr. A fuel regulator and restrictions in a line is what causes pressure usually measured in psi. Volume and pressure are directly proportional in this matter, and the fuel system could supply a ton of fuel at a low pressure, or not so much fuel at a very high pressure. This is the reason that fuel injectors, fuel pumps, and fuel systems are upgraded in cars because in the end the system cannot support enough fuel going into the cylinders.
The LSJ and the L61 use the *exact* same fuel filter. I recently changed the fuel filter in my 07' SS/SC and my GF's 08' LT, and it was the exact same filter, lines, etc, however a different pump is in the tank. The fuel filter has *nothing* to do with fuel flow or fuel pressure, unless you want to get technical and say that the restriction of the filter causes increased pressure and decreased fuel flow in a small sense. The fuel filter is however where the stock system returns fuel to the tank. Yes, the Cobalt stock has a 'return style fuel system', however it is at the rear of the car, and is not boost referenced or anything, but instead has a simple regulator in the canister in the tank). The fuel pump flows fuel from the tank through the feed line, to the filter, where the flow is split inside the filter, hence the 1 inlet and 2 outlets. Some fuel is sent up to the engine, while the other portion of fuel is sent back to the tank via the return line where it passes though a ball bearing and spring regulator where it is then difused and splashed over the fuel pump to help cool it. That return line to the tank and the regulator causing a restriction is what causes the 58psi stock fuel pressure.
Look at all of the people running E85 or high boost high fuel applications who are still using the stock LSJ pump... The stock LSJ pump after 2005 is a great pump and it flows as much if not more than the Walbro. The 2005 LSJ pump is junk however. The fuel system efficiency can further be increased by using a return style regulator system or rewiring the fuel pump for more voltage hence stability and flow.
I am not sure of the specs on the 2.2's fuel pump, but I'm sure it is not intended to flow near as much fuel volume. If you have a 2006 or 2007 LSJ pump, use it. And no, you can't 'burn u[' a pump in that sense. Yes, it's an electric motor and will fatigue and wear out like anything else, but it's not like the faster you go the harder it pumps... The fuel pump will fail just as easily cruising on a 500 miles trip as it will doing back to back dragstrip passes.
Yes, the LNF is different... The filter is in tank in the LNF. The LNF uses some sort of cam driven fuel pump on top of the engine as well. The fuel pressures are wayyyyyyy higher to support the direct injection. I have never torn one apart like I have a LSJ system so I won't pretend to know anymore about the LNF lol.
You're 100% sure, that the flow of fuel, is not measured in psi? Wtf..
#113
thought maybe you were looking past 300
#115
o i understand now lol. once you said wife i was like o **** i should have shut my mouth. lol but i would tell my wife nothing about my build than when she drives it and tries to pass a car and guns it. and the turbo spools up and she is like wtf!!!!!!!!!!!!!! lol be the funniest **** ever.
#119
................wait..................i get. still stands......hahahahahahahahahahahahahahahahahah... .................................................. .................................................. ........................................all the ******* way to the crazy house
#123
Yeah, but there is still pressure in the fuel lines, is what I mean. Which means there is pressure that occurs from the pump, all the way to the injectors.
I'm sure it is a different part. If they just changed the numbers then that means they are selling the wrong filters to people.
Exactly.
