Spark advance table for boosted L61
Old 05-01-2016 | 06:53 PM
matthud's Avatar
I have recently turbo'ed my L61. I am using a standalone ECU. I was hoping someone that has turbo charged their L61 could share with me their spark advance tables, and for what octane.
My ECU does not have provisions to read the stock knock sensor, so I don't have any feedback on knock count. I had a running setup for NA, it was not optimal but it ran. I have no data for the positive pressure section on my map.
Any help is appreciated.
Old 05-01-2016 | 11:12 PM
ItalianJoe1's Avatar
you'd need to check with someone who has the same ECU. Tables from HPT won't fit into yours. If you're looking for a rough idea of what to start with and go from there, it can be from any boosted car, the general idea is about the same, timing goes way down as boost comes up, more so than regular N/A WOT sections. Largely dependant on what fuel you use if you can get a lot of timing in it.
Ecotecs like to run 16-18 on boost setups on pump gas, but without knock detection i'd start at 12 degrees and build from there, back off when you stop gaining power.
Old 05-02-2016 | 03:29 AM
matthud's Avatar
Any Speed Density based advance table for a turbo 2.2 will help. I understand timing has to be dropped with boost, I would just like to get a general feel for how the 2.2 should be across the entire RPM vs MAP range.
16-18 on 93? At what boost pressure? At what RPM?
Last edited by matthud; 05-03-2016 at 09:57 PM. Reason: Meant Speed density not Alpha N
Old 05-02-2016 | 02:10 PM
sandman's Avatar
I was at 14 wide open
Old 05-09-2016 | 12:38 AM
06_ion2's Avatar
I see about 16 on 17lbs with 91. Readings from a dashhawk
Old 05-11-2016 | 04:40 PM
jdbaugh1's Avatar
On a stock L61 engine I used to run about 15 degrees at WOT with M62 on 3.1" pulley making about 10-11 psi. This was mainly to try to prevent the possibility of bending a rod.
Our engines should be able to make power up to 24 degrees ignition timing advance. That is what I am running now with TVS and 2.9" pulley and water/methanol injection because I couldn't get over 14 without knock on 91. I am now running with my knock sensor unplugged because it is erratic and was robbing me of power by retarding my spark from false knock. You should be able to hear knock if you listen for it. However, I'm not sure how much detonation stock internals can handle without exploding.
Old 05-11-2016 | 08:26 PM
sandman's Avatar
Not much.
Old 05-12-2016 | 12:17 AM
Start out with 12-13* peak in the boost regions. Incresing from maybe 6-8* at low rpm to 13* at higher rpm.
Old 06-27-2016 | 07:46 PM
TFD's Avatar
TFD
Stock 2.2 L61
Garrett T25G turbo @ 12 psi
2.5bar TMAP
470cc injectors @ 3.8 bar base pressure
Map needs some more tweek but no knock with this one on my setup.
Maybe take 1-2 degrees outy in boost area to make sure.
Cman46290
07-01-2016 09:56 AM
QuickSilver_SS
05-02-2016 09:41 PM
ccsssc
04-30-2016 03:09 PM
Oscar1204
04-28-2016 01:25 AM
jcobaltss
04-24-2016 08:28 PM
Quick Reply: Spark advance table for boosted L61
