speed limit
speed limit
last nite me and my friend were out last nite (those in washington will know where meridian is) and is was empty so we were gunna see how fast we would go.. well i had it floored in 5th gear and it was just hovering around 98mph... is this a limiter or governer or sumthin.. ??
yea i dont think i redlined in 4th but i still would think that you would get some push out of 5th gear.. i dont know if it was cuz it was raining or what.. i just know my foot was to the floor
typically your overdrive (or second overdrive) gear(s) is/are totally for fuel economy. Your motor makes its horsepower at a higher RPM then you were running at 98 MPH in fifth gear. Essentially, you were drag limited because you were in too high of a gear. Try running it in fourth if you are all fired up about top speed and see where it ends up. Once you redline fourth, you might go up a touch in 5th or you might drop down, just depends on the power output after your 4-5 shift.
ryan
From what i have learned the base cobalts have different governed speeds depending on the tires that u got from factory. The base cobalt with continental tires is governed at 105 ish and the ones with the upgraded tires i have heard can go as far as 120. I have also heard rumors that if you upgrade your tires to a higher speed rating that GM will flash you comp for that higher speed.
Originally Posted by DoNtGeTdUnNuP
cobalt30 is just a *****.. jk but it was pretty intense.. umm how does the ss front bumper line up with the rksport side skirts and rear valance.
No he isn't. Speeding, especially 100mph, in the rain is a recipe for killing yourself...
100 MPH in the rain is ass holish. Not only are you putting your self in danger, but everyone else on the road as well. That was pure stupidity, and I dont want anyone trying to justify it.
I had my dealer reflash my comp. for my new rims, they were like .5 in bigger than stock rim and tire combo so they did the reflash with the new specs and tire rating. Charged me nothing and the limiter is gone as far as I can tell.
there was no1 else on the road.. *******.. just my life in danger.. and whats life if ur always playing it safe.. nothing.. i need thrill.. something to get my blood rushing
ok i got the ls coupe with the sport package and a 5 speed if i red line 4th i get 120 and it just seams to cut fuel after that cause i dont accelerate much in 5th but from what ive read it come down to tires my tires are rated to 130 so the limit is set at 120 the other tires are 112 and most poeple with those get to about 105 or 108
how about you dont try topping your car out until you know how to drive it first... i only say this since you obviously cant drive a stick too well if you didnt know to downshift.
Originally Posted by Cobalt30
your an idiot. why would u choose to see how fast your car is on a night that its raining.
ryan
ryan
I also agree that you need to learn how to drive better, it doesn't take long at all to hit the governor in 4th gear. But if you are having a hard time try dropping it down into 2nd...
i added a intake to my car this week...i took it out on a long stretch of highway yesterday on my way to work....first off i have a base model 5 speed with the continental tires....well i started going went all the way to redline in 4th and pulled out 125mph b4 i let out b/c of i knew the tires couldnt handle it...but once i get my 18s back on im going to see where it stops at
Yeah, I got my base model right up to 105, and it was a smooth ride up to 105, but then the oh so rude governer kicked in and dropped me down pretty quick.
That was definately a rude and unwanted surprise. But if the tires arent rated for higher than that, I can appreciate the limiter.
well first off when ur at 100mph in 5th ur at what like around 3500 rpms? with the cobalts gearing of 3.58 :;assuming u have a 05 non ss s/c:: the car wont get much power....why not stay in 4th at 100mph? i mean u can get to 125mph in 4th and be at 6200rpms.....why be in 5th at 100mph?
well if you guys are all so ****** smart.. why doesnt 5th gear have power to get me past 100 easily if the rpms arent that low..
Hey bro,
You need to chill out. Cut the attitude and cursing and maybe people will respect you.
