squires turbo systems remote mount, update
#303
i dont want to hear any kind of woooshhh air sound, i want it to sound like the BOV on the eclipse from the first fast and furious.... High pitch ear ringing whistle with no sound of wooosh because it was dround out by the whistle
#305
My all time favorite is on this vid at about 0:50 the best one ever gauranteed!!
http://youtube.com/watch?v=J9CKLSjBzL8
#309
Well, since this is the 5th time i had to fix the collector gasket, something isnt lining up right sooo..... I ordered a new shorty header and down pipe
watch the first fast and furious and listen to the eclipse when he revs it up and the BOV whistles pretty loud, im pretty sure its a typeS bov on it. if i can find a video of the sound ill post it
i found out what type of BOV it is... its a Greddy type-S
#313
i just noticed this, how the hell did i miss it, i ran a 10.01 1/8 mile when i made my 15.7 run...weird, actually ur on a pretty big turbo, so you dot se boost till a bit later, im assuming ur time would be better than 15.7 seeing how youll be in full boost after the 1st gear
#314
#316
Now that we know where about the turbo starts making boost he has adjust it acordingly and starting when my new header and downpipe come in i will be going against my 10psi limit/goal and going for 15psi. I am kinda worried about the axels though because i didnt mention this earlier but since he tuned the tranny to have UPPED line preasure, when the car shifted to second i got wheel hop from the 5psi of boost
ohhh and the reason for only 5psi was so that if the computer didnt like boost i wouldnt have ran a HUGE risk of blowing up the motor from boosting it.... Remember i have a 5,000 motor build in there that i dont want to blow up and have to start over again
#317
yeah man for tuning you have long road ahead of you. But, tell him to look at the fake 2-bar tunes used by the s/c'd and turbo'd cavi's. I'm sure some of those settings an be transferred to your car. also if you play with the voltage adders and etc on the injector tables you should be able to get it to control the 60lb injectors no prob
#318
#319
well I'm glad that you've come to realize that getting this tune straight is going to take more than 2 hours.
One question though, why can't you run a different MAP sensor?
Also, what was your trap speed in that 10.0 1/8 mile?
#320
that last part didnt really make sence to me because the ss/sc makes boost after the maf and not before it so i dont know how that works
here are some new pictures guys
my new MRZ superman strut covers
#321
I'm not sure if the ECM will let us change out the MAP or not. I'd have to ask him if there is an option to change that in the ECM tune. Vince says that he is sure we can get around the MAP for boosting the car what he is worried about is hitting the wall on the MAF, thats what he called it. Pretty much he doesnt want to hit the point where the MAF reaches its max reading of air flow, but he did say that the MAF on the 2.2 is the same as the MAF on the ss/sc so he is pretty sure that we wont hit the MAF wall.
you can swap map sensors, we all can....to a limit.
none the less, if you run outta maf just bump the maf pipe sizing, and retain that size from maf, to TB / compressor.
you low freq resolution will suffer, but thats no uber deal.
to swap maps you need to know what KPA the sensor has to be at to output 0V and what KPA is has to be at, to output 5V
swap that into your tables and there you go.
run a SS/SC MAP and the numbers are already known so you'll have less work to do.
#322
the last part about the MAF you confused me with. you are you saying keep the size pipe i have now and just where the maf is make that part larger and then go back down to the pipe size i have now to the throtle body
because i read your TB as throtle body and the TB / compressor as both to the throtle boday and back to the turbo compressor
#323
its simple here...
what size pipe do you have the maf in?
the best compromise so far is 3in pipe.
once you jump to a 3in from what ever size charge pipe you run, you must maintain that size until the TB.
the reason behind this is air velocity, we jump size to slow the velocity, if you drop size back down after the jump up, you negate that effect, and induce tons of unneeded turbulence.
#324
ahhh ok, its 2.5 inch pipping right up to the blow off valve and then after the blow off valve its the fujia CAI and i believe its 3inch because there is a step up coupler joining the two together
