squires turbo systems remote mount, update
#426
Dude that looks pretty sweet honestly, anyways. I see where your coming from, I guess because I am pursuing an Auto degree at the local tech school it doesnt look too bad to me. I kinda know how to weld(would just have my teacher do it) but otherwise not too bad. Looks great, been dyno'd yet?
#429
i think around the time the OP started there was 3-4 of us workin on turbo builds at the same time,
me, mike25, and this guy, and i think mr silent finished before all of us, and if im correct, mrsilent is down, and so is the OP, i saw them go down and said i quit, and i think mike had his kit for sale for a while now...dunno if he ever finished
#430
#431
i get to see it!!!!! yay!
bout damn time too adam lol
when ur done with ur break in period, it will be interesting to see how this beast opens up.
are u gonna be in michigan long?
#433
adam, nice to hear you're about to be rolling again. sounds like ill be doin my breakin at the same time as you. I should be fired up friday as well. good luck on the breakin period man. I wanna see how your powerband is on those cams cuz I plan on getting some new ones before I go with a larger turbo.
#435
the plan is as soon as i touch down friday night im going to take the car out and rack up, or as close as i can, 100 miles and then change the oil saturday morning. Then put another 100 miles on it coming down to great lakes crossing mall near you and change the oil again while im down there. Then she will be good for some WOT data logging for Vince and send the resaults to him so he can adjust accordingly and then do that process repeated until he has it right. He already had a good starting point with me and now an updated starting point w/ an HHR sts that he tuned. So i would say that it shouldnt take too much tweak and peak of the tune after the first WOT data log. I would say probably about 3 to 4 hours of work.
#436
Std "high po" ecotec brake in goes as fallowing.
1) Start car on NON-SYNTHETIC oil...let idle and reach full operating temp. idle for ~20min.
shut off and drain oil.
2) REFILL with NON-SYNTHETIC AND NEW FILTER for the next 100mi
Drain oil.
3) REFILL again with NON-SYNTHETIC AND NEW FILTER for ~500mi.
drain oil.
4)REFILL with SYNTHETIC AND NEW FILTER drive for 2000mi.
drain oil and refill, use new filter.
5) Resume normal oil changes.
the non-syn oil is thicker and will capture metal shavings better, it will also allow more friction between the new rings and the block so they bite in quicker.
Drain oil.
drain oil.
#437
Drain oil.
drain oil.
Drain oil.
drain oil.
now the motor that i blew up, yeah, i should have broke the engine in that way since it was all "high po" parts in it
#438
my 2 new sts video's
http://www.youtube.com/watch?v=p0ZfCCn4Fx4
http://www.youtube.com/watch?v=iAR9wj60qbs
