squires turbo systems remote mount, update
#126
Well... to keep my promise....
First, the Civic probably has VTEC, which means it has super retarded lift when it hits.
Next, the Civic has a great flowing head from factory.
These things you may have come equivalent to with your cams and head porting... so let's assume that in those aspects your now on a level playing field.
Where does the Civic continue to have an advantage?
It revs to nearly 9 grand, for starters.
Along with the single most part that you have over looked in every HP number you've posted... static compression.
The civic has at least a 10:1 compression in there... as compared to the 8.9 you swapped in.
Boost will have less of an 'amplifying affect' with respect to boost input on your lower compression engine. You will be able to handle running higher boost, but will make less power on the same amount of boost being ran.
This is the same for the 350Z (10.6:1), Civic Si (11:1), LS1 'vette, (10.1:1). These car just listed also have the advantage of having significant;y better designed heads, and way larger displacement.
Soooo.... if a guy on a stock compression engine is making 212HP on 8psi... you probably won't see to much higher, if at all higher.
Too late... already did part 1 of operation turbo n00b
#127
yeah i did over look the compression thing.... this kind of posting actually helps me to understand better... everyone else just bashed, no help what so ever.... we'll see how it goes today when i go in to tune the car and dyno... if i dont make at least 280whp the next post you will see will be a piston swap to 11:1 and a crank swap so i can take the revs higher, my valve train is already good for 9k rpms, its the crank that blows nuts
#128
If you go too high, you run the risk of having to pull a lot of timing, and have increased cylinder temps.
You can take advantage of your lower compression pistons, though, but just running a higher amount of boost into the engine. I'm not sure what Trifeca's boost limitations are, but it's your easiest and cheapest way of using what you've got.
As far as teh reving... I'm pretty sure that we are limited to 8000k RPM for most Ectoecs (not sure on the 2.2's, other are limited by the stock ECU). I'd say that's far enough to go. With decent cams, 8k should be far enough... you just don't want to over extend the rev limit, and not be making any power up top.
#129
so far trifecta has only tuned for 10psi of boost and working. so that is the tune we are using on my car for now and we are going to fine tune it for my application.... once my new cv axels come in ill be upping the boost to 15psi as i had already planned on before hand
#130
At 15psi you should see some not to bad numbers... I'm skeptical of 300hp though.
You'll have to play with the boost, AFR, and timing on the dyno to find the sweet spot as far as what makes the most power, while still being safe.
#133
Chevy Cobalts come with two different transmissions depending on your model. Here is some info.
Here is the GM transmission guide.
http://www.gminsidenews.com/index.php?page=trans_guide
2.2L/2.4L Automatic
Hydra-Matic 4T40E/4T45E
Type: four-speed front-wheel-drive, electronically controlled, automatic overdrive transaxle with electronically controlled torque converter clutch.
Engine Range: 2.2L-3.5L
Max Gearbox Torque: 325 lb.-ft.
Weight: 188 lbs.
Assembly Site: Windsor, Ontario
Applications: Chevrolet: Cobalt, Malibu, Pontiac: G5, G6, Saturn Vue 4-Cylinder.
With a max TQ rating of 325 lb/ft, it doesn't seem to be the weak link..
2.2L/2.4L Manual
Getrag F23
Type: transverse front wheel drive, five-speed manual transaxle.
Engine Range: 2.2L-2.4L
Max Gearbox Torque: 170 lb.-ft.
Weight: 102 lbs.
Applications: Chevrolet Cobalt, HHR; Pontiac G5
2.0L Supercharged
GM Europe F35
Type: transverse front wheel drive, five speed manual transaxle.
Engine Range: 2.0L
Max Gearbox Torque: 258 lb.-ft.
Weight: 99 lbs.
Applications: Chevrolet Cobalt SS
2.2L/2.4L Automatic
Weight: 188 lbs.
2.2L/2.4L Manual
Getrag F23
Weight: 102 lbs.
2.0L Supercharged
GM Europe F35
Engine Range: 2.0L
Weight: 99 lbs.
I dyno'd at 151 before i reduced my engine compression, after i reduced my engine compression i dyno'd at 142whp wasnt that big of a drop but i did notice the drop in hp when i ran the 1/4 before and after, ran 3tenths slower
#134
then maybe they can explain why a 350z yield 440whp on 7psi remote mount turbo? or why a civic Si yeild 314whp on 7psi remote mount turbo? or why a base vett yield 536whp on 7psi remote mount turbo? hell even a v6 stang yield over 400whp on 7psi remote mount turbo
even if i do manage to hit 300whp and i posted video they would still call the video a fake or something to that effect. its just not worth putting forth the effort.
if you think, in ANY way, shape, or form that any eco head you have will net the flow of a STOCK VQ35 head your dumber then i previously thought.
the si has been covered, so we'll move on. Once again the same basics apply for the vette. the turbo, and engine are moving **** tons more air then your car can ever hope for, thus the massive power difference you WILL see when this disaster hits the road.
take this idea with you and go away.....
an STS system could be brutally efficient on this car, in a matter of words, however your bastardization of it has turned its possibilities into large, power sucking flaws.
for the people who want to do this style of a turbo system, the correct way, and make more power then this tool will at the same boost level....let me know.
however, if you manage to make 300whp at say 18psi or so, yey! however it'll still be a base model with a rattle can'd body kit and the wrong trans.
i've tired to help in the past, you wanted to be hard headed. now i'll go away and just wait for the first dyno pull to be massively disappointing.
btw- fixed some of your spelling errors.
I dont know where you got your info from, the automatic is what i have
celicacobalt has a smaller turbo then i do. 06Blackg85 has the exact same turbo as i have on my car and is making 411whp on 21psi, im going to go ahead and guess somewhere around 320 to 330 is what i should be on 15psi, and 270 is what i should be around on 10psi
#135
BUwhahah, lets deal with just the 350z for starters.... if we take all the factors of larger displacement, rev ability, cam profiles, valve size,ect and toss them out the window, your left with just the basics. AIRFLOW
PLEASE do that....
quite being ignorant here, if you think that pauls turbo is going to act remotely the same on your car, with this set up, your mistaken....by a huge margin.
PLEASE do that....
#136
I'd suggest 10:1 (close to stock).
Also, about me making 212whp on 8psi, thats a much smaller turbo then his, i gotta say. My turbo is a TD04H-19(largest of the TD04's). It will flow about 480cfm MAX. With my engine(7k redline) and altitude thats about 17psi on it and ill be lucky to make 280whp.
#137
i have a t-60-1 hifi with ceramic ball bearings... not sure what the CFM's are on it but its max HP out put is 530 crank horse power @ 30psi
#138
ok so you have no idea the CFM but you think it'll hit 530 at 30 psi?
hell no not on your setup.. the c-1 procharger pushes 1000CFM max.. and on their site says if can produce 625 hp at 24psi.. but chevytech wasn't seeing anywhere near there on 23 psi....
#140
ok man i'm gonna have to go against you now..
THE 60 SERIES! Turbochargers
Compressor Maps
Compressor Wheels/Housings
Ceramic Ball Bearing Option
Backplates
Bearing Housings
Turbine Housings
The 60-1 Performance Turbocharger
Representing the careful marriage of a unique high flow/high efficiency compressor section teamed up with a T4 turbine section the 60-1 has proven itself in every competitive motorsport application from drag racing to Bonneville. Available with either the standard (4” inlet, 2.5” discharge) compressor housing or the 60-1 Hi-Fi ( 2 3/4” inlet, 2” discharge) compressor housing, the 60-1 will outflow any standard T04B with ease! (The 60-1 Hi-Fi will deliver approximately 90-95% of the flow capacity of the standard 60-1.)
#141
I was looking at that turbo, but id have to do some serious modding to fit it behind my engine and i just want 350whp so a EvoIII 16g will cut it for me.
You can make some serious power with that turbo, just not on that low of boost. just go at it like the rest of us. Dont say "im gonna make this", say "im going for XXXwhp, but we are tuning at 10psi first to see where im at. Then everyone will be behind you hoping for good numbers.
#142
here is the link http://www.turbocharged.com/catalog/t60.html ill keep looking for the percision site
#143
especially seeing as i'm not seeing that you did any head work.. your head will not flow nearly enough to efficiently max out that turbo
#144
#145
#146
yeah thats something im worrying about too. But damn are those things a bit spendy. I'll be picking up the StgII 400hp axles when i get the EvoIII 16g.
Also Adam(if you dont mind me sayin that), dont delete this thread ever. Because its got a LOT of information in it that future turbo guys can read. All of us have posted some great information for the next guys. If your gonna do anything, just lock it.
#147
tahts all well and dandy.. jsut because it's capable of making that much hp doesn't mean you're going to get anywhere need it is my point...
found the percision web site http://www.precisionturbo.net
#148
#149
