SS injectors...
SS injectors...
what would be the benifit of putting new injectors on my 2.2...or possiby gettin some outta an SS.....???....plz help
sry for the n00b question...lol
sounds good... btu i wanna know the difference between my stockers and the ss stockers....someone has got to know....and if they benefit my performance...then ill be glad to buy your injectors...lol
yeah...you can't just put the injectors in....the stock 2.2 injectors are i believe 22lb and the ss/sc injectors are 32lb...if you use the ss injectors then you have to tune for them...which is mainly a waist of money without f/i and even with the ss injectors you will only be able to use them up to about 210hp unless you up the duty cycle insanely which will lead into alot of problems...so if you go turbo you have to take in account what your hp goals are and how you will achieve them....different turbo trims and cfm rates make different power so take that into account..after you have decided your power goals and what turbo is going to be right then choose your injectors....
Price_is_Right
05-20-2015 05:25 PM
