Stg 2 zzp bolt on too much?
My plan is to buy the stg 2 bolt on supercharger kit from zzp over the winter and install it during the summer. My only concern is whether or not the stg 2 would give me more than 250whp, because I don't want to do anything with the internals. In addition to the kit I will have header, dp, catback. Any feedback is appreciated.
Response from zzp.
it depends on rpm but with stock valve spring and those mods, I would expect 210WHP
Originally Posted by Zooomer
Originally Posted by nickadolph
Do you have any idea how much whp I would make on a 2.2 l61 if I'm running you're stg 2 bolt-on kit with a header/dp/catback? I'm trying to keep the power as close to 250whp without going over to preserve the reliability of the engine. Is there a certain configuration you would suggest to go with my hdr/dp/catbk so that I would make around 230-240whp? Thank you for any assistance you may be able to provide.
Yup Its will all of your supporting mods, and I would highly recommend valve springs! if you think that you can just slap on a stg 1 and have 230whp you are truely mistaken.
Have you been dyno'd?
Alright, so seeing as I'll probably have buy more than just the kit and gauges do guys think I should keep the G5 stock and buy a second car (4th gen Camaro/firebird), or keep just the G5 and mod the hell out of it? Cause I can get a used v8 for just a grand or two more than what I would spend modding the G5. All opinions welcome, including suggestions for 2nd car.
