Stock SS spring or Sportlines?
Would it be worth my while to get a good deal on some used SS's springs or just go with & save up for sportlines?
i want to put 17's on my 4 dr & lower it some but just wanted some input.
thanks,
Dave
thanks,
Dave
depends on how low you wanna go i guess... the sportlines are about the most aggressive lowering spring you can get where the stock ss is going to be barely noticeable might even out the back end a bit... I say sportlines if you wanna go really low or just to level things out i would say get the eibach pro kit :P SS Springs probably not worth it at all.
yeah, i want to lower it but not like a ton. i was looking at the pro kit too. ill prob end up going with that instead. with some 17's & the pro kit which drops it 1.4 front & back it should look nice.
Look
FE5 Shocks/Struts with Prokit on 17" Rims
I got the Cobalt Addiction Springs on my LS if you wanna take a look at my thread
https://www.cobaltss.net/forums/pictures-videos-64/installed-ca-1-springs-my-ls-165911/
they are not as much of a drop than sportlines but alot more than the pro kit (imo) i love them!
here...h&r sport springs (eleventy billion times better then sportlines lol..lower drop, better handeling...= awesome) and ss springs, both are base model ls cobalts, mine is the silver on h&r, gfs is on ss/sc (sportlines are about the same as the h&r drop wise...just about .1-.2 less) and mine has 17" rims with REALLY low pro tires
easiest way to show this=
some more pics to show
If I ever go with koni shocks I'll be sure to drop with h&r springs. Nothing against sportlines I'm just looking to lower as much as I can without going into coilovers.
I noticed the H&R Race Springs lower just a bit more than the sport springs.
and yes, they will work with stock struts and shocks, bu tyou will get a better ride and better handeling out of nicer ones, even if it is just ss/sc/ or ss/tc ones
If I was you I would buy new ones because the ride would be good until they blow then the ride would be horrible...or just save up around a thousand dollars and get coilovers but its your choice and either will be a good one...
Sportlines or H&R are what you want for springs.
I have Sportlines on stock shocks/struts(FE1) and it's an OK ride. I'm going to be upgrading to SS/TC shocks and struts in the future (maybe next summer...depends how long mine make it....I've been lowered for about 8 months so far).
