Stupid question I'm aware.
Okay... it's been awhile since I looked under my hood, but I'mma ask this question anyways.
If I was to turbo my 2.2L base, would I still have room for the custom 2.2L intakes?
I've no idea where the turbo mounts vs. the posistion of an intake cause I've never seen a turbo on a car. I do think the placement of the intake the SS was different if my memory serves me right, and I believe that the reason aside from the Supercharger placement is there is a different hook up to the engine due to size or something on the SS.... so that was probably all just run together in a single thought.... if anyone understood it, gimme a heads up with the original question. Thanks.
J
J
well part of the turbo is the intake, so no custom intakes can be used with a turbo set up, cuz the turbo pushes air through an "intake" right to the throttle body, so basically the intake is part of the whole turbo set up, but it has to be custom made straight to the turbo
with a supercharger you should still be able to do most of the n/a mods since a supercharger runs off a pulley and not off of exhaust gases like a turbo so an intake would be fine for a supercharged application just not on a turbo application
I'm old school
Originally Posted by nomoreavril
wouldnt the same apply to a supercharger? no point in buying an intake if you're gonna get a supercharger?
Yes, a forced induction system (super or turbo), still has to "take in" air from the outside. You were asking however about specifically getting an intake first, then a turbo afterward. That would not work. The intake systems that are out there are designed with duct work that routes directly into your throttle body. A turbo system would replace that duct work with it own, and would then locate its air intake in a completely different place.
As for the supercharger on the SS, the intake systems for that are designed specifically to replace the one installed by the factory. So the duct work will match.
You wouldn't need to get an intake with a turbo system, because the system would come with its own. You could certainly put a different air filter element on the intake, but you wouldn't need to change the actual pipes.
