super charger 2.2
super charger 2.2
Ok i was looking around and found a super charger kit for a Cavalier OR Sunfire 2.2 ecotec
http://www.crateenginedepot.com/stor...-P1377C41.aspx
Can i get input on this and can it be done to my 2006 cobalt LT 2.2
I Realy dont see why not they are the same motors ...
The blower would be a lot easier for him to install, the price is pretty reasonable also. It will probably fit but you should do a lot of research to be sure, the cobalt/ion will probably get a specific one out pretty soon if they don't already.
Well, one difference is that cavaliers with the ecotec have the speed density set-up where it uses the MAP sensor to detect vacuum inside the motor. Now the cobalts have a MAF sensor, you would have to make some modifications to make it work with that as well.
I'm old school
This is an OLD TOPIC. Please do a search before making new thread.
NO this supercharger WILL NOT WORK on the Cobalt.
The article in the build book is specifically for a J-body car.
The Cobalt uses a completely different fuel control system then the J-bodys, which is why the kit would not work. Additionally, some of the mounting hardware is different.
The Cobalt is getting its own kit, which has not yet been released.
i thought the build book was made around a cobalt and noted that most of the listed mods would also work on the j's...theres an easy way to find out for sure, call gm technical support.
I'm old school
The 250-400 build section applies to Ecotec engines in general, so both j-bodies and Deltas.
Originally Posted by alleycat58
It is in the build book, but it does not fit the Cobalt. "GM Performance Parts has develop a bolt-on supercharger kit for the 2.2L Ecotec engine. Fits 2003-2005 model year Cavalier and Sunfire. Also fits certain 2002 Cavalier and Sunfire equipped with Delphi fuel inejectors (<I assume that to mean injectors...).
I'm old school
Originally Posted by mike25
then why does it show em bloting the supercharger onto a cobalt
Originally Posted by sshaner
i think it will fit, i would wait for a turbo more torque and more hp from turbo!!!
Yes and No.
They are both great power adders.
The SC is a much simpler install.
Depending on what the goals are, a SC could be just as good if not better.
I personally agree with you that a Turbo is the better power adder most of the time, but the SC always must be considered as it has some fantastic proerties as well.
Originally Posted by YellowLT
My dealer had one and they mocked it up and it doesnt fit. It hits the hood and the radiator. the new manifold is too big
Originally Posted by Brian MP5T
Having said that, with some modifications to the header, will it work on the engine?
Where Can i find the Ecotec 2.2 Handbook online....? If i can make the supercharger worked on the 2002 Ecotec engines for the Cavalier, i can recommend this to my friend for future decisions.
Also,...Would the tranny need to be changed on the sunfire/cavalier or can it stay automatic.....?
