Supercharger Build!
Old 02-19-2012, 12:03 AM
  #226
heathkidder's Avatar
yeah i plan to i just bought the hoses tonight and made it up real quick.. it does look wierd but it should work fine. it came like that from zzp so it should work fine.
in there how to it says to put the vacuum hose on the small barb from the mani and then connec the map sensor on the other end and use a small zip tie around each end to hold it. and thats directly from there how to sc kit
Old 02-19-2012, 12:06 AM
  #227
AzraelRaezier's Avatar
they gave u the "install book pic things"?
Old 02-19-2012, 12:09 AM
  #228
GSDIESEL300's Avatar
They gave me a how to as well and it didn't say anything about that lol. My intake mani came with a nipple so maybe that's why.
  #229
yes i have there how to with pictures and also how to remove all the stock parts and everything.
Old 02-19-2012, 12:10 AM
  #230
Doomstar's Avatar
I recommend using an Oil Catch Can with your setup.
Old 02-19-2012, 12:35 AM
  #231
why an oil catch can?
Old 02-19-2012, 12:39 AM
  #232
BankerBalt's Avatar
because it assures you get little to no oil in the intake so your tb doesn't get all gunky
Old 02-19-2012, 12:43 AM
  #233
yeah but if you run a breather off the VC you wouldnt have that issue anyways correct?
Old 02-19-2012, 12:45 AM
  #234
BankerBalt's Avatar
true but then your breather will just get oily and gross and not be able to breath very well after a certain time. and you'll just have to replace that too
Old 02-19-2012, 12:47 AM
  #235
touche.
Old 02-19-2012, 12:55 AM
  #236
im not getting a catch can right now. i no ppl who never use them but i plan to down the road. iv spent enough as of right now lol
Old 02-19-2012, 12:57 AM
  #237
did you get that email? idk if it sent right if not ill try again for ya
Old 02-19-2012, 12:59 AM
  #238
yea it did. i just dont have microsoft office on my computer so ima open it tomorrow and print it off on my parents laptop
Old 02-19-2012, 01:01 AM
  #239
yeah i never did either i just installed it and uninstalled it lol
Old 02-19-2012, 01:10 AM
  #240
ha. ima just download it to their laptop tomorow and print it off and stick it in a folder in my tool box.
Old 02-19-2012, 01:11 AM
  #241
yeah i have it in a folder. a friend asked me to keep track of the money i have spent so i have that also lol
for any1 who has a ttr upper engine mount. how long does the vibrations last?
Old 02-19-2012, 01:25 AM
  #242
im up to about 1100$ right now with my build. still need wideband, boost gauge, and tune. and the window res.
Old 02-19-2012, 01:38 AM
  #243
window res? you mean windshield washer reservoir? i wish i was at that low but with my header/dp/exhaust and other things not really needed last i checked i was around 2500
Old 02-19-2012, 01:50 AM
  #244
im not counting the exhaust stuff ive done cuz that was already on my car before the build. once i get the wideband, tune, and exhaust stuff ill be up around 2000
Old 02-19-2012, 02:03 AM
  #245
where can i get some hose clamps like the stock ones not those ones you have to screw on
Old 02-19-2012, 09:19 AM
  #246
Axelthered05's Avatar
junk yard has lots if you cant find them at a store just my .02
Old 02-19-2012, 09:25 PM
  #247
not sure if there are any close by but ill be sure to check
Old 02-19-2012, 09:48 PM
  #248
pick and pull is a good place check there web site
but im sure you can find them at home depo for sizes under 1"
Old 02-20-2012, 12:04 AM
  #249
ok can any1 tell me what this hose is for obv a ground so can it be moved to any other bolt it is hittin the intake mani and causing it to not sit properly not sure where to put it theres not many choices near by just wondering if any1 else moved this?
Old 02-20-2012, 12:08 AM
  #250
when you took off ur manifold did you move all the wires over to the far right bolt?
Last edited by AzraelRaezier; 02-20-2012 at 12:08 AM. Reason: Automerged Doublepost
Quick Reply: Supercharger Build!
