Supercharger Build!
#226
yeah i plan to i just bought the hoses tonight and made it up real quick.. it does look wierd but it should work fine. it came like that from zzp so it should work fine.
in there how to it says to put the vacuum hose on the small barb from the mani and then connec the map sensor on the other end and use a small zip tie around each end to hold it. and thats directly from there how to sc kit
#241
yeah i have it in a folder. a friend asked me to keep track of the money i have spent so i have that also lol
for any1 who has a ttr upper engine mount. how long does the vibrations last?
#243
window res? you mean windshield washer reservoir? i wish i was at that low but with my header/dp/exhaust and other things not really needed last i checked i was around 2500
#249
ok can any1 tell me what this hose is for obv a ground so can it be moved to any other bolt it is hittin the intake mani and causing it to not sit properly not sure where to put it theres not many choices near by just wondering if any1 else moved this?
