Supercharger Build!
#251
yes i moved a wire so the intake mani bracket would fit this is a totally diff. wire
thanks for the pic i have another wire with the wire im tryin to move ill try to bend the bracket to make it work
#253
#254
i got the 5 size bolts required for the intake mani but not the other 2 just yet. but there so much smaller than the stock ones for the 2.2 mani why cant i just reuse them? one other ? i have there are two holes on each end of the hole in the middle that look alot bigger than the rest what size bolt goes there?
#255
also i had to bend the ground wire to fit right because another plug was hitting it
the two prongs on the end of the wire were just bent so i could face the ground wire down instead of ontop
#267
i no it snaps together but silver piece is just a back up security for it is all. tonight i installed my injectors, took the header off but then i realized iv missed place my deep socket set for the dp so that will wait till tomor night and installed the h/e which was a bitch
BTW where does the injector harness plug into i have all these wires layin around and tryin to figure each of them out. thanks
