Supercharger Build!
#353
At the shop I go to,they only charge me a $30 install charge.I always supply my own muffler/ resonator though.Search ebay for your size resonator/glasspack.they are not that expensive.You can even go to a local auto part supply and use a cherry bomb glasspack as a resonator.I've seen a couple catless LSJ's do that and they sounds good as hell
#355
pretty much.It's just filled with fiberglass to help absorb sound and they are straight through so they are not restrictive. and yes what ever size catback you have.
#358
Yea i cant drive the car till it stops snowin anyway thats why iv takin my time lol next year im buyin a wood stove
Y do u have to switch the two sensors around
#365
it was pretty decent here today. i started to make my custom mounts for my heat exchanger. but when i went to test fit the mounts i figured out a better way to mount them so i had to run back to lowes to get more material by the time i got home. it was getting windy and cold. buy a portalbe heater and stick it in your garage. thats what i do to warm it up. we've got a "space" heater. after about an hour of being plugged in it brings the garage temp up enough to make it tolerable
#368
Walmart.com: Howard Berger Co Deluxe Milkhouse Utility Heater, CZ798: Heating, Cooling, & Air Quality
this one may be good for a garage because its got a metal frame to it. the one i have is plastic but i use it in the house and out in the garage
just look at walmart. i have a 3 car garage and i have 2 space heaters. after about an hour or so it warms up the garage enough that i can work out there and after working for a bit im usually comfortable
#372
installed my exhaust ... aftermarket hangers SUCK!!!
suppost to be cold again this weekend but mon and tues. look nice so ill prolly wait till then to do anything else .. next is taking off the bumper and puttin in the washer reservoir and taking the old one out and puttin in the intake
