Supercharger Build!
#388
give me a minute i'll try find a pic iirc it's on the passenger side of the car.
http://www.gmtunersource.com/racerte...book-chapter-1
download this if you haven't already and go down to fig. 16 it's page 11. there's a drain valve and it just comes down through the drain tube
#393
just to be sure this does this hose routing sound right
starting from the h/e bottom hose goes to filler neck the top hose goes to ic pump the other hose in the ic pump goes to middle fitting in dual pass the other 2 are held with a t fitting to the other end of the filler neck?
#394
got the upper rad. hose on and my h/e fittings also unwrapped most of the maf sensor but im just gonna buy the extension from zzp to make life easier lol tomorrow im doing my hose routing and w/e else i have time for.
#399
well went to put intake on and i got the lower part in since i have a 2 piece but i need to redo my wire loom before installing the top part. put the lsj washer fluid reservoir on also real quick and luckily i had a few bolts layin around to mount it. im tryin to get the coolant off everything still lol it doesnt evaporate
