Supercharger Build!
Old 03-06-2012, 11:48 AM
  #376
mgray21's Avatar
Did you end up getting glowshift?
Old 03-06-2012, 11:50 AM
  #377
heathkidder's Avatar
no i got aem i will also be gettin the boost and volt digital aem gauges
Old 03-06-2012, 01:53 PM
  #378
im tryin to install the lsj washer reservoir and i cant seem to get the plug and line to the other side any tips?
Old 03-06-2012, 02:01 PM
  #379
GSDIESEL300's Avatar
You have to buy a fitting and more of that small hose and route it around the engine bay.
Old 03-06-2012, 02:03 PM
  #380
what about the plug for the pump just cut the wires and splice them together?
Old 03-06-2012, 02:07 PM
  #381
Ya, just get some of the same size wire to extend them with butt connectors, or you can solder and heat shrink them if you prefer.
Old 03-06-2012, 02:16 PM
  #382
alright ill see what i can find at the store thanks.
Old 03-06-2012, 04:05 PM
  #383
zerosk8ter83's Avatar
nice nice
Old 03-06-2012, 11:18 PM
  #384
bluebalt07's Avatar
Not true. All you actually need to do is pull the connectors of the sprayers and swap them and the hose will reach perfectly to it's new location
Old 03-07-2012, 02:09 AM
  #385
Old 03-07-2012, 06:53 AM
  #386
klutch814's Avatar
lookin good man!
Old 03-07-2012, 10:58 AM
  #387
Can sum1 tell me where the drain plug is for the radiator
Old 03-07-2012, 12:07 PM
  #388
conerboner's Avatar
give me a minute i'll try find a pic iirc it's on the passenger side of the car.
http://www.gmtunersource.com/racerte...book-chapter-1
download this if you haven't already and go down to fig. 16 it's page 11. there's a drain valve and it just comes down through the drain tube
Old 03-07-2012, 12:53 PM
  #389
i said eff it and just took the upper hose off and watch a mess flow infront of my eyes lol
Old 03-07-2012, 01:05 PM
  #390
it doesnt matter which is in and which is out on my h/e does it? if so which is which ?
Old 03-07-2012, 01:13 PM
  #391
IonNinja's Avatar
Yes it does, highest fitting is in and lower is out
Old 03-07-2012, 01:17 PM
  #392
thanks
Old 03-07-2012, 01:20 PM
  #393
just to be sure this does this hose routing sound right
starting from the h/e bottom hose goes to filler neck the top hose goes to ic pump the other hose in the ic pump goes to middle fitting in dual pass the other 2 are held with a t fitting to the other end of the filler neck?
Old 03-07-2012, 03:09 PM
  #394
got the upper rad. hose on and my h/e fittings also unwrapped most of the maf sensor but im just gonna buy the extension from zzp to make life easier lol tomorrow im doing my hose routing and w/e else i have time for.
Old 03-07-2012, 03:30 PM
  #395
just bought spark plugs from ottp and maf ext. from zzp.
ordering boost and volt gauge tonight and im done i hope lol
Old 03-07-2012, 06:35 PM
  #396
Axelthered05's Avatar
why did you put your upper rad hose on before the supercharger?
Old 03-07-2012, 06:43 PM
  #397
bluebalt07's Avatar
^this. It's possible to get the supercharger on with the hose there but it will probably get in the way enough to **** you off lol
Old 03-07-2012, 07:28 PM
  #398
The bottom isnt one just top part
Old 03-08-2012, 03:12 AM
  #399
well went to put intake on and i got the lower part in since i have a 2 piece but i need to redo my wire loom before installing the top part. put the lsj washer fluid reservoir on also real quick and luckily i had a few bolts layin around to mount it. im tryin to get the coolant off everything still lol it doesnt evaporate
Old 03-08-2012, 06:34 AM
  #400
looking good man I bet you can't wait to get her running
Quick Reply: Supercharger Build!
