Supercharger Build!
Old 03-08-2012, 11:51 AM
  #401
AzraelRaezier's Avatar
God this looks good. Cant wait to see it running
Old 03-08-2012, 03:35 PM
  #402
heathkidder's Avatar
Yea its coming together nicely
Old 03-09-2012, 03:11 AM
  #403
which one of these are right
Old 03-09-2012, 03:30 AM
  #404
redcobalt07's Avatar
Well you don't have directional arrows on your second diagram soooooooo.
Old 03-09-2012, 03:36 AM
  #405
i just need the right diagram i just looked at a how to and seen a 3rd way to do this?
Old 03-09-2012, 04:09 AM
  #406
any1?
Old 03-09-2012, 08:39 AM
  #407
taerae86's Avatar
lol this is why i was wondering the same thing last weekend...we had mine routed kinda like the first one before you sent me that pic, just with opt b, so we left it that way after getting that pic lol
Old 03-09-2012, 12:02 PM
  #408
I think its done either way
Old 03-09-2012, 12:08 PM
  #409
Doomstar's Avatar
I can make you one, what are you 2 running? Stock H/E, S3, Dual Pass? You have the Pump Bracket ?
Old 03-09-2012, 12:21 PM
  #410
Zzp h.e dusl pass pump and filler neck
Old 03-09-2012, 12:44 PM
  #411
bluebalt07's Avatar
Here's a pic of how mine is routed.
Easiest way IMO because there's not a whole lot of room for hose routing and tightening connections
Old 03-09-2012, 12:57 PM
  #412
drumrush's Avatar
heath, you can use either the first one you posted or bluebalts
Old 03-09-2012, 01:03 PM
  #413
1LowLS's Avatar
Bluebalts is how mine is routed!and it works really well
Old 03-09-2012, 01:10 PM
  #414
Why don't you run an option B?
Old 03-09-2012, 01:15 PM
  #415
c1_c1rca's Avatar
i sent you these in a pm you sent me
these are off genes build
Old 03-09-2012, 01:16 PM
  #416
drumrush's Avatar
he has a zzp s3 heat exchanger, which means that he cant run the line for bleeding air
Old 03-09-2012, 01:40 PM
  #417
Doomstar's Avatar
There you go.
Old 03-09-2012, 02:42 PM
  #418
bluebalt07's Avatar
I have the zzp heat exchanger and option b tank but instead of running a bleeder line I just made it a flow through tank and it bleeds air like a champ
Old 03-09-2012, 03:44 PM
  #419
I just didnt want opt b my cooling mods are far more than i need unless i would ever pulley down which i have no plans to byw thanks to every1 for the help
Tomorrow i shoukd be done finally
Old 03-09-2012, 07:09 PM
  #420
Originally Posted by Doomstar
There you go.
Im gonna do it like this thanks
Old 03-09-2012, 08:23 PM
  #421
IonNinja's Avatar
this is the "Option A" routing per the GM dual pass instructions FYI
http://s3.amazonaws.com/zzpstorage/i...al+pass+IC.pdf
Old 03-09-2012, 08:37 PM
  #422
GSDIESEL300's Avatar
There you go.
Do it this way. I checked mine tonight, it's the same as this drawing. I must have done more research when I was routing mine and found that the image I gave you had the top and bottom of the heat exchanger mixed up.
Old 03-09-2012, 09:07 PM
  #423
Ya looks like either way works just wanted to be sure
Old 03-10-2012, 01:12 PM
  #424
Doomstar's Avatar
I made it just for you lol.
Old 03-11-2012, 01:51 AM
  #425
how does this look my ac line is so close its in the way to come up with any type or routing but this it doesnt appear to be kinked thats why i made it loop out far enough what do you think
also my sc is hitting the injector clips. stock they sit at an angle but is it ok to be moving these over to bolt the sc down? i dont want them to be leaking later on?
Quick Reply: Supercharger Build!
