Supercharger Build!
Old 04-04-2012, 09:55 AM
  #576
jbenso4's Avatar
Originally Posted by AzraelRaezier
im using the fuel pump fuse too but im getting a code for the fuel pump relay circut not sure whats going on there.
its drawing too much power from the fuel pump. Vince said thats a no no. I forgot what I used, I will check and let u guys know
Old 04-04-2012, 10:58 AM
  #577
bluebalt07's Avatar
I used the daytime running light fuse. It's one of the few that's only on with the ignition. You just have to make sure you never turn off the auto lights.
Old 04-04-2012, 11:33 AM
  #578
drumrush's Avatar
I always turn off my auto lights. Not sure what to do then
Old 04-04-2012, 12:48 PM
  #579
heathkidder's Avatar
Same here hmm idk wat else to use anyone?
Old 04-04-2012, 03:34 PM
  #580
IonNinja's Avatar
Doesn't the how-to on here say to use the fuel pump fuse?
Edit: Nvm just read the previous page lol
Old 04-04-2012, 10:30 PM
  #581
Validater's Avatar
You can try using the SAI fuse. Its the one used for the coolant pump on the LSJ.
Old 04-04-2012, 10:31 PM
  #582
AzraelRaezier's Avatar
i thought the coolant pump on the LSJ was controlled by the computer and it didnt turn on till they reached certain IAT's?
Old 04-04-2012, 10:59 PM
  #583
bluebalt07's Avatar
I think Validater is right that it is used to run the pump on LSJ's because I think I read it in the manual but it didn't work when I tried it.
Old 04-06-2012, 08:20 AM
  #584
taerae86's Avatar
what intake did you end up getting? is it three inch?
Old 04-06-2012, 11:30 AM
  #585
Ottp 3 inch
Old 04-06-2012, 01:07 PM
  #586
huckernage's Avatar
i m using ABS fuse. i have no abs on it. my AFR is on it too
Old 04-08-2012, 07:50 PM
  #587
Any1 no how many gallons of gas our cars hold
Old 04-08-2012, 08:14 PM
  #588
GSDIESEL300's Avatar
13 gallons
Old 04-10-2012, 02:10 AM
  #589
Wat gap is every1 using on the plugs i just put mine in as they came from ottp
Old 04-10-2012, 08:21 AM
  #590
taerae86's Avatar
i want to say mine were at .034...
did you get it running?
Old 04-10-2012, 08:39 AM
  #591
mine are at .35 so pretty much the same as taerae, btw, did you get your tune cable working tae?
Old 04-10-2012, 09:20 AM
  #592
taerae86's Avatar
negative...but i've been talking to vince and he's workin on it so we're on the right track lol
Old 04-10-2012, 09:43 AM
  #593
bluebalt07's Avatar
Vince had me gap mine to .028
Old 04-10-2012, 11:55 AM
  #594
c1_c1rca's Avatar
i used the sunroof fuse, i dont have a sun roof lol
Old 04-10-2012, 07:52 PM
  #595
Wonder wat gap plugs come outta the box i didnt mess with them unless vince says to
Old 04-10-2012, 08:36 PM
  #596
huckernage's Avatar
i m using stock plug and stock gap
keep it simple men
Old 04-10-2012, 09:16 PM
  #597
conerboner's Avatar
keep it simple men
I wish it was simple lol. stock plugs stock gap with boost is no bueno
Old 04-10-2012, 09:20 PM
  #598
the ngk ones i baught came gapped at .40 out of box. im at .35 and running strong as ****. but im also on e85 so idk if a bigger gap is required for that.
vince didnt even ask what my plugs were gapped to. haha
Old 04-10-2012, 10:42 PM
  #599
bluebalt07's Avatar
My NGK's were at .40 out of the box as well and I can't remember what I gapped them to but I was having misfire issues and vince had me gap them at .28 to try and take care of the problem
Old 04-11-2012, 12:20 AM
  #600
Thanks guys
Quick Reply: Supercharger Build!
