Supercharger Build!
Old 04-15-2012, 12:58 AM
  #651
heathkidder's Avatar
it says its for a turbo though?
Old 04-15-2012, 01:22 AM
  #652
Axelthered05's Avatar
just get the 3" one and conect it to your tb
Old 04-15-2012, 01:30 AM
  #653
aw hell no that intake was a bitch to get on with those lines in the way lol ill get it if i really have to thought thanks for the link.
Old 04-15-2012, 10:13 AM
  #654
well you could always put it at the end of your intake just take off the filter and do it that way
Old 04-15-2012, 12:03 PM
  #655
nhanson's Avatar
As long as you torqued everything good there shouldnt be boost leaks.
Old 04-15-2012, 02:48 PM
  #656
Well if u member i had my map located weird so i was just double checking
Old 04-15-2012, 02:56 PM
  #657
huckernage's Avatar
are you using 2.2 map sensor in SC manifold hole on right side?
Old 04-15-2012, 03:00 PM
  #658
I am but im not the boost nipple was welded shut so there is a fitting coming from where the map normally sits then a t fitting for boost line and map sensor
Old 04-15-2012, 03:08 PM
  #659
nhanson's Avatar
It would most likely be a vacuum leak at idle so start spraying starter fluid around
Old 04-15-2012, 05:06 PM
  #660
what do you mean "boost line" is that one going to your boost gauge?
Old 04-15-2012, 05:12 PM
  #661
c1_c1rca's Avatar
yes^^^^
Old 04-15-2012, 05:14 PM
  #662
c1_c1rca's Avatar
i just had a boost leak and everything was tightened down properly, one of the o-rings on my injector seat was pooched and was spraying fuel and air out of it once i hit boost... didnt know this till i saw my car up on the dyno last week
Old 04-15-2012, 05:19 PM
  #663
nhanson's Avatar
One reason i suggested the starter fluid
Old 04-15-2012, 05:23 PM
  #664
c1_c1rca's Avatar
yeah i tried that but didnt spray the injectors lol
Old 04-15-2012, 05:24 PM
  #665
huckernage's Avatar
can you show us a picture of this setup
i ll send you 2 pictures
i use sc sensor to block this hole and use this little thing on monifold top
pic to come
Old 04-15-2012, 05:37 PM
  #666
huckernage's Avatar
Old 04-15-2012, 06:57 PM
  #667
Pics are in the first few pages
Old 04-16-2012, 05:48 PM
  #668
huckernage's Avatar
that is nice
Old 04-16-2012, 09:29 PM
  #669
Trifecta= fail
Vince is on vacation till end of month great so much for gettin my car on the road
Old 04-16-2012, 09:38 PM
  #670
nhanson's Avatar
Trifecta= fail
Ask for refund and do HPT
Old 04-16-2012, 09:51 PM
  #671
bluebalt07's Avatar
As long as it runs and you're not knocking or anything should be fine to drive until he is back
Old 04-16-2012, 10:46 PM
  #672
padlock's Avatar
^my thoughts exactly!
your acting pretty darn overcautious considering this isnt the first tune vince has ever done like this. I'd at least go take it out for a spin and see how she runs other than idling
Old 04-16-2012, 11:15 PM
  #673
taerae86's Avatar
wait, you have your tune on and you haven't data logged or drove it? Did I miss something? Lol
Old 04-17-2012, 01:27 AM
  #674
I data logged and am waitin for 2 tune first tune is usually a base file so why would i go out drivin it when its not runnin perfect
Old 04-17-2012, 06:22 AM
  #675
conerboner's Avatar
You have to data log it driving on the base tune. first one should be idling, normal driving, and wot if everything feels good.
Quick Reply: Supercharger Build!
