Supercharger Build!
#676
#678
so i have this damn ticking or clickin noise and it sounds like its coming from header/dp but at start up i can hear it alot then it almost goes away that i cant hear it once i rev it you can hear it again. iv tightened down all the bolts on header/dp and exhaust 3 times now and all the gaskets are brand new. can anything else be causing this clicking
#681
it may be older gas I'm guessing as well..
seeing as you dont drive it, its going to take a while for the older gas to get through the system.. depending how much was in it
#685
im talkin about the lifter? the timing chain u just take the valve cover off and its on the back of the head right? but why would my timing chain randomly do this now is it bad or was it something i was suppost to do when i sc'd it
#686
I'm guessing (just a complete guess), that it would make the most sense to be the tensioner if the noise is coming from that area. I'm not certain as to if you need to run a different one when you go s/c'd but it wouldnt surprise me if you did need to due to the strain's the s/c puts on the belt as compared to just being N/a
like i said, total guess but thats my logic on it.
i'd doubt it would be a lifter as you never touched internal stuff what-so-ever, so I'm basically tossing that idea out..
#687
yea its coming from the back area it seems but ill check it again tomor see if its comin from more of the side area. hopefully timing chain isnt hard to install though ... is it ok to drive the car till i get one ?
#689
where did you did your kit? did u buy part here and there?
Remove and inspect the tensioner. doomstar has eveything inside was in bad shape
#698
mine bounches around 13-15ish. under wot im like 12.6 right now. but i think since im running e85 my fuel filters starting to get clogged up since the alcohol is cleaning out my gas tank so im going to swap my fuel filter in a week or two when i get the money for one and see what happens. when i first did the build i was at 11.5afr under 10lbs of boost or so
#699
is e85 worth it?
#700
lol i dont have a ******* clue what my afr readings are, my sensors been fucked ever since i got it, i need a new one... but i know from my dyno that im running extremely rich, in fact i could probably rig up a spark plug in my tail pipe and shoot fire..... :p
