Supercharger Build!
Old 04-17-2012, 08:30 AM
  #676
taerae86's Avatar
Originally Posted by conerboner
You have to data log it driving on the base tune. first one should be idling, normal driving, and wot if everything feels good.
this...
Old 04-17-2012, 11:35 AM
  #677
heathkidder's Avatar
I data logged st idle and normal driving now waitin 2 weeks to drive the car
Old 04-22-2012, 12:15 AM
  #678
so i have this damn ticking or clickin noise and it sounds like its coming from header/dp but at start up i can hear it alot then it almost goes away that i cant hear it once i rev it you can hear it again. iv tightened down all the bolts on header/dp and exhaust 3 times now and all the gaskets are brand new. can anything else be causing this clicking
Old 04-22-2012, 12:54 AM
  #679
.... - YouTube
Old 04-22-2012, 12:56 AM
  #680
could it be from the old gas or oil sittin so long although i drained it doesnt it need to reach a certain pressure or something
Old 04-22-2012, 01:13 AM
  #681
padlock's Avatar
it may be older gas I'm guessing as well..
seeing as you dont drive it, its going to take a while for the older gas to get through the system.. depending how much was in it
Old 04-22-2012, 02:10 AM
  #682
conerboner's Avatar
Have you upgraded to the new style timing chain tensioner? if the sound is coming from that side of the engine it could be that
Old 04-22-2012, 02:13 AM
  #683
padlock's Avatar
buddy of mine with a built LSJ just watched it and said it sounds like either a lifter or chain tensioner. so chain tensioner may be it!
Old 04-22-2012, 02:33 AM
  #684
Ugh im unsure wat that even is lol is it a simple fix
Old 04-22-2012, 02:42 AM
  #685
im talkin about the lifter? the timing chain u just take the valve cover off and its on the back of the head right? but why would my timing chain randomly do this now is it bad or was it something i was suppost to do when i sc'd it
Old 04-22-2012, 02:48 AM
  #686
padlock's Avatar
I'm guessing (just a complete guess), that it would make the most sense to be the tensioner if the noise is coming from that area. I'm not certain as to if you need to run a different one when you go s/c'd but it wouldnt surprise me if you did need to due to the strain's the s/c puts on the belt as compared to just being N/a
like i said, total guess but thats my logic on it.
i'd doubt it would be a lifter as you never touched internal stuff what-so-ever, so I'm basically tossing that idea out..
Old 04-22-2012, 02:52 AM
  #687
yea its coming from the back area it seems but ill check it again tomor see if its comin from more of the side area. hopefully timing chain isnt hard to install though ... is it ok to drive the car till i get one ?
Old 04-22-2012, 03:09 AM
  #688
wouldnt the timing chain make that ticking noise all the time though? even at idle
Old 04-22-2012, 09:04 AM
  #689
huckernage's Avatar
here u go
where did you did your kit? did u buy part here and there?
Remove and inspect the tensioner. doomstar has eveything inside was in bad shape
Old 04-22-2012, 11:42 AM
  #690
First off hes not tslkin about that and 2 i dont even have that
Old 04-22-2012, 03:58 PM
  #691
huckernage's Avatar
1 just try to help u out. 2 it was a similar sound 3 idk which part u have and which u dont....
Old 04-22-2012, 08:12 PM
  #692
I didnt mean to sound like a smart ass but i have zzp idler setup it was a leak i found it today
Old 04-23-2012, 04:00 AM
  #693
c1_c1rca's Avatar
nice, a leak where?
Old 04-23-2012, 08:57 AM
  #694
Header
Old 04-24-2012, 02:14 AM
  #695
Wat should my afr be at idle? At wot it should be in the 11's right
Old 04-24-2012, 05:52 AM
  #696
huckernage's Avatar
14,7 it can be waving between 14,5 and 15,2.
Old 04-24-2012, 11:06 AM
  #697
bluebalt07's Avatar
Mine bounces between 13.5 and 16. And unless I get hp tuned that's probably the best I'm gonna get
Old 04-24-2012, 04:39 PM
  #698
AzraelRaezier's Avatar
mine bounches around 13-15ish. under wot im like 12.6 right now. but i think since im running e85 my fuel filters starting to get clogged up since the alcohol is cleaning out my gas tank so im going to swap my fuel filter in a week or two when i get the money for one and see what happens. when i first did the build i was at 11.5afr under 10lbs of boost or so
Old 04-24-2012, 05:27 PM
  #699
huckernage's Avatar
no more wot for you
is e85 worth it?
Old 04-24-2012, 05:46 PM
  #700
c1_c1rca's Avatar
lol i dont have a ******* clue what my afr readings are, my sensors been fucked ever since i got it, i need a new one... but i know from my dyno that im running extremely rich, in fact i could probably rig up a spark plug in my tail pipe and shoot fire..... :p
Quick Reply: Supercharger Build!
