Supercharger Build!
Old 05-08-2012, 08:05 PM
  #826
heathkidder's Avatar
Yea i no so just push the pin in and plug the holes and then thats it lol
Old 05-08-2012, 08:06 PM
  #827
GSDIESEL300's Avatar
Yea if it hold the pin in then it's good, if it comes back out then it needs replaced.
Old 05-08-2012, 08:08 PM
  #828
Ok ill try doing this tonight
Old 05-08-2012, 08:12 PM
  #829
nhanson's Avatar
Thanks for info...didnt know that.
Old 05-08-2012, 08:23 PM
  #830
Do either of u have vids of ur gauges while in boost so i no how much it should be changing
Old 05-08-2012, 08:26 PM
  #831
nhanson's Avatar
i can get one tonight...always like to exercise the car
Old 05-08-2012, 08:28 PM
  #832
No but it shoots to 15-16 psi in less than a second and stays there until I let off lol.
Old 05-08-2012, 08:29 PM
  #833
Well without taking it off i put my finger over the hole and pushed the pin inside and it stayed so doesnt that mean its fine
  #834
nhanson's Avatar
what pulley?
Old 05-08-2012, 08:30 PM
  #835
If u could plzz lol u can even text the vid if ur doin it on ur phone
Old 05-08-2012, 08:32 PM
  #836
Possibly, I think so. Try plugging only the top one and see if that works as well. If that works too then its fine.
what pulley?
2.9" how many psi do you have?
Old 05-08-2012, 08:33 PM
  #837
nhanson's Avatar
will be in 720 HD so no texting...lol
and it sounds like something is getting blown out when it gets in the upper PSI
can you manage part throttle and see what 7-8 PSI does?
  #838
I plugged the one that we dont put a hose on
Old 05-08-2012, 08:35 PM
  #839
Like get on it alil and see what i hit?
Old 05-08-2012, 08:36 PM
  #840
Try plugging the one with the hose on it too. They should both work.
Old 05-08-2012, 08:39 PM
  #841
K ill take it off after work and check it and prolly replace the hose
Old 05-08-2012, 08:40 PM
  #842
nhanson's Avatar
yea
  #843
You can probably try and just pinch the hose and see if that works.
Old 05-08-2012, 09:02 PM
  #844
Where else is common for leaks
Old 05-08-2012, 09:16 PM
  #845
nhanson's Avatar
Vacuum connections...boost gauge?
Old 05-09-2012, 12:02 AM
  #846
nhanson's Avatar
http://www.youtube.com/watch?v=rUpUzb4qliU
Old 05-09-2012, 12:12 AM
  #847
Thanks ill get one and post it
Old 05-09-2012, 12:25 AM
  #848
cobaltalex's Avatar
i was only gettin 3-4 psi then flip flopped the tubes on the nipples and then hit 10 psi and got a big smile.
Old 05-09-2012, 03:10 AM
  #849
Flipped what ? And i think it might be my gauge hell idk i got on it and i coukd hear the whine but it was at 0 then shot to 15-16 and back down abd i let off
Old 05-09-2012, 03:35 AM
  #850
My gauge is digital but shouldnt matter it seems to pull just as hard as when i kept hitting 12 so im not sure whats wrong
Quick Reply: Supercharger Build!
