Supercharger Build!
Old 02-17-2012, 02:07 PM
  #201
heathkidder's Avatar
Yes but thats why the map is connected with thst hose
Old 02-17-2012, 02:11 PM
  #202
kingg5's Avatar
Ahh ok but why? Seems kinda janky...
Old 02-17-2012, 03:52 PM
  #203
Bc the boost nipple is broke
Old 02-18-2012, 03:33 AM
  #204
installed the idler pulley and spacers
Old 02-18-2012, 04:01 AM
  #205
zerosk8ter83's Avatar
nice
Old 02-18-2012, 04:52 AM
  #206
i no your suppost to loosing the bolt on the tensioner to get the belt on but im unsure what to loosin exactly any help?
Old 02-18-2012, 08:21 AM
  #207
Axelthered05's Avatar
ok if your using the stock tensioner there is a small square slot in it which you can plug a 3/8 breaker bar which will allow you to pull the tensioner away from the belt loosening the tension
Old 02-18-2012, 08:23 AM
  #208
there is a beter description and pictures on becks how too https://www.cobaltss.net/forums/how-...through-80620/
Old 02-18-2012, 10:57 AM
  #209
Ok i mean belt is like last thing installed so ill look into it thanks
Old 02-18-2012, 10:44 PM
  #210
any one got tips on taking out the two cores to install dual pass i dont want to break them but i twist and pulled and i cant get it to budge
Old 02-18-2012, 10:48 PM
  #211
GSDIESEL300's Avatar
I tapped my lightly on the sidewalk and they just fell out. You could also use a small pick to try and pull them out.
Old 02-18-2012, 10:49 PM
  #212
iv been tryin everything lol
  #213
AzraelRaezier's Avatar
put a towel under while you tap it. so if they fall out you dont damage them.
Old 02-18-2012, 10:50 PM
  #214
Yes, use a towel under it. They won't break without one but the ends or the cores or the manifold will scratch.
Old 02-18-2012, 10:51 PM
  #215
yeah that would suck to mess tehm up. im using this info for when i do my build
Old 02-18-2012, 11:05 PM
  #216
ok got them out but one went in just fine but the other sticks out for some reason it wont go all the way in
Old 02-18-2012, 11:26 PM
  #217
drumrush's Avatar
Make sure all the gaskets and o-rings are in the right place on all 4 cores
Old 02-18-2012, 11:29 PM
  #218
drumrush's Avatar
Originally Posted by 1LowLS
1/2 inch which is too big.you have to stick with 3/8" for the VC.
I have half inch on mine
Old 02-18-2012, 11:39 PM
  #219
that was the issue gasket and ring got stuck inside it so i had to get a knife and fish it out lol then it went in fine.
Old 02-18-2012, 11:41 PM
  #220
dual pass installed. and here is my new map sensor installed
Old 02-18-2012, 11:48 PM
  #221
thats deff a weird setup. haha. cant wait for more pics.
Old 02-18-2012, 11:55 PM
  #222
thats how it came from zzp the guy said lol so im not sure. but it works. the boost nipple had been welded shut or broke off i guess and so thats why they used this fitting so you can use it as boost reading and map sensor.
Old 02-18-2012, 11:58 PM
  #223
yeah. i still have the boost nipple on mine. and im just gonna put the 2.2 map sensor in that spot since i wont be reading IAT2's but i gotta figure out how to plug the hole in the top of the sc
  #224
That's weird man, I'd be worried about the boost pressure blowing the hose off of the gold fitting.
  #225
drumrush's Avatar
You might wanna shorten that hose a bit
Quick Reply: Supercharger Build!
