supercharger question?
I think the OP should make double sure it's the M62 then and make sure everything works properly. I know it's only 20 bucks, but why spend it on a broke part or the wrong part all together?
I guess the answers will be mixed, but I did some searching and came up with M90 as well...I believe that's all the Bonne, GP, and Regal GS came with, but I could be wrong.
The M62 supercharger was manufactured by Eaton, exclusively for the GM 3800 engine. HP was rated at 205 for 1991-1993 engines (models vary), and 225 for 1994-1995 engines.
In 1996 the Eaton Generation III M90 supercharger was introduced and used through 2005. Power is up to 240 hp (180 kW) and 280 lbˇft (380 Nˇm) of torque.
Haz l33t wheelz.
what does the intake neck look like? it could very well look waay different.
I may be wrong, but i believe both the 03 Terminators and 02 Jaguar XJR's both had Eaton M112's, but they look very different. The rotor packs are what make the size.
http://cgi.ebay.com/ebaymotors/1994-...spagenameZWDVW
i havent taken it off the car, and the one there selling on ebay is exactly the one thats on the broken down bonne.
Fail Less.
The blower that the early 90s bonnevilles had is an earlier generation M62 blower. neither the snout nor inlet is the same configuration as our M62s. While it may bolt to the ss/sc manifold, you will have a bitch of a time making it work due to the intake side and snout/pulley not lining up at all.
Keep looking.
Keep looking.
EDIT: maybe i lied... it might just have a different housing with a shorter intake neck...
its definitely an M62 actually, but it wont fit in a cobalt since the intake neck is too short and the belt driven section is also too short (it wont reach the belt location when installed on the factory manifold)
