Supin Up An Intake?
Supin Up An Intake?
yo i decided to post this under 2.2 since i have one....wut would u guys think if i port and pollished my intake...is it even possible....idnt kno much about this topic so i decidedd just to throw the idea out their....and as u can see im pretty desperate for power....and dnt tell me to go turbo LOL THANKS
doesnt matter how wide the intake is if the throttles still stock anyways...and even then.....if you want more power after intake and exhaust...youll have to go with incrased piston compression, new camshafts (requires a tune), and raising redline (also requires tune)
What they are saying is that you can't do incrased piston compression, new camshafts, and raised redline, because there is not tuning available.... you'll have to wait on most of that, but if your question was about putting an alum. intake mani. and p&p'ing it yes you can do that....
intake is the exact same as exhaust in the sense that your piping is only as big as your smallest point (with few exceptions since air can compress)
at any rate, your not going to see a gain without porting your throttle body as well
Cheap to manufacture and it's a simple design that is effective.
I don't know where you guys have gotten this information.
Porting is a drilling method used to increase a diameter. Polishing helps with airflow. Your aftermarket intake is alluminum and typically are very thin as is. There is no benefit in increasing the diameter.
You would not be improving anything.
If he was talking about the intake manifold...
You could DREMMEL the intake manifold.
The problem with this is that you would decrease air intake velocity the larger you make the runners. This would essentially move your powerband upwards. Like Hunterkiller said, it would not benefit you to do something like this unless you are capable of drawing more air in and in that effect, you're probably moving your powerband upwards anyways.
Last thing, please people (not just Red06LS), instead of telling people what they should buy, ask them questions. Find out what the poster is looking for realistically from the car and not to do things just because they have some drilling tools around their house. Doing something like this could mess something up and if there are shavings left inside the manifold and put back on, you could cause actual engine damage. You would also be effecting airflow dynamics.
Bigger is not always better. Air velocity is a huge effect on an engine.
It wasn't made for the 2.2 specifically but it's on the Saab 9-3s (2003+) 2.0 Turbocharged ECOTECs. They are alluminum BUT I would not suggest someone getting this item unless they are either turbocharged or drawing in a significant amount of air per engine cycle or increasing engine cycles per min (RPMs). It is a higher flowing manifold than your stock plastic manifold.
Also understand that just because your manifold is plastic DOES NOT mean that it is:
1. A bottleneck on your intake system
2. Not capable of flowing the proper amount of air
3. Weak
I'll put it simply, if you have NO engine work done and you're not running a turbocharged setup, there is no benefit for someone to have this manifold.
but you have to follow the restriction rule
The stock manifold and the stock throttle body size IS capable of flowing enough airflow. Until someone starts to:
1. Increase RPMs
2. Do valvetrain upgrades (mainly changing the intake camshaft)
3. Increasing compression (like you said)
The throttle body's stock size (58 MM) MIGHT be a restriction point.
Also, I don't know how well you'll be able to bore the electronic throttle bodies.
I'm old school
He's talking about his intake, not his manifold.
There is no such thing as porting and polishing an intake. It's just a pipe. There is nothing to port or polish about it.
Damn, Adam beat me to it. With a lot more words.
Like NJHK said, I don't think P&P would make much of a difference at all with just an intake. Especially with the stock plastic manifold. It is smooth already.
But if you got the saab manifold, you could p&p. But what I've heard is that the saab manifold already flows more air than ours stock. Not saying to buy it, but to research it.
I think he would actually have better results with just polishing. Making the intake smoother, wouldn't it speed up the intake air velocity, resulting in just slightly more power. Or if not power, wouldn't the engine rev a little faster?
Gotta keep on your feet ol' timer.
Plus, you beat me a few times in the past, so consider this revenge
I've been around the ECOTECs (especially L61s) for years, that's kind of why.
I was about to say.
How the hell does one go about porting an aftermarket intake? The damn things are only like a 1mm thick anyway.
Rep added to NJHK for mad knowledge
Adam is all over this **** lol. I was just pointing out that its plastic all the way to the engine, i wasnt sure what part of the intake he was talking about. But at any rate i think he has been straightned out now.
I'm all over it like me on some chicken...mmm...chicken...
OrangeCoba
09-25-2015 06:06 PM
