Synthetic Oil for LS
Old 02-03-2008, 04:26 PM
blu3_v1p3r's Avatar
I'm thinking of switching to Mobil 1 Syntec, anyone who has a 2.2 what kind of improvements have you seen?
Old 02-03-2008, 04:28 PM
kenhebe's Avatar
You won't really feel an improvement per say. It might gain you a couple of horsepower, but nothing noticeable due to the improved lubrication. It is more of a longevity thing. Better oil lubiricates better and reduces heat. Less heat let the motor live longer. Just keep in mind that once you switch to full synthetic, you can never go back to conventional.
Old 02-03-2008, 04:30 PM
Projekt's Avatar
you will gain as much horsepower as a alpine decal
Old 02-03-2008, 04:32 PM
kenhebe's Avatar
Not true. Going from conventional to fully synthetic will increase your wheel hp, but not very much.
Old 02-03-2008, 04:33 PM
blu3_v1p3r's Avatar
I wasn't looking for horsepower, iw as talking about maybe since the engine will have better lube, it might run more quite, or maybe my engine temp would be lower
Old 02-03-2008, 04:36 PM
kenhebe's Avatar
Your engine temps will be a little lower, but not much. Maybe 5 degrees, but every little bit helps.
Old 02-03-2008, 04:39 PM
mkulrey13's Avatar
you wont really notice anything. Just that it will cost you more . Ive put mobil 1 fuly sync since i bought the car back in 05. Runs like a champ with 60k on the clock.
Old 02-03-2008, 05:18 PM
tonio5555's Avatar
Go to Walmart... buy some Mobil 1 for a good price. (around here 5 quart container is like $23.) When I switched to synthetic I think the car felt a little smoother, but not necessarily more powerful. It could all be in my head though. Scientifically it is proven that Synthetic lubricates better which means better longevity for the motor.
Old 02-03-2008, 05:23 PM
07BluBalt's Avatar
i use a full synthetic motor oil and have since my first oil change, most of the time you wont notice a power increase, but occasionally in some cars you might be able the feel smoother acceleration smoother/firmer shifts. everything just seems to run a bit better, i recommend using synthetic oil in all cars, not that much extra to pay for and your doing your car a great service. Another good thing to do is at time of oil change add some fuel additives/cleaners (for your valves and whatnot). i use shells brand V-Power, keeps everything clean and im hoping my car will last a bit longer with the way that i drive.
Old 02-03-2008, 07:34 PM
pacific cobalt's Avatar
I have been using castrol syntec for 2 years now and if you rev your engine hard everyday like I do then you should use a full synthetic
Your engine will last longer and run a little smoother overall
Got 1 hp increase according to my G-Tech Pro SS
Old 02-03-2008, 08:20 PM
cobalt_addict's Avatar
guess it doesn't matter to you but for us up north full synthetic Really helps on the cold starts.
Old 02-03-2008, 11:12 PM
Cobalt4Life's Avatar
i use royal purple and i did feel a difference in acceleration and smoothness, and car felt way better at startup.. i also use royal purple coolant additive, droped my temps pretty nicely..
i never used mobile 1.. but from my experience it did make quite a impact on my car.. it aint a huge difference, but i did notice it the first startup.
Old 02-04-2008, 09:38 AM
409Cobalt07's Avatar
i have run nothing but mobil 1 in my 2.2 and it runs great...
Old 02-04-2008, 09:45 AM
D4u2s0t's Avatar
that's such an old myth. that's up there with the octane booster that will take a second off your 1/4 time in a stock 89 civic.
you can go back and forth all you want. you will not feel a difference in acceleration or most likely anything else. i don't care what anybody says, but nobody can tell me that they can really feel a difference between 125 and 126 hp
Old 02-04-2008, 09:49 AM
cobalt_driver's Avatar
cudn't have said it better. i've been running with synthetic since i believe 3k on the car. What u'll gain is smoother ride, less oil changes (its stays alot cleaner), and ur car will die with like 298,000 on it. Its only good if u use it early in the cars life.
Old 02-04-2008, 10:05 AM
RedBaseBolt's Avatar
I've been using synthetic since the first 500 kms.
I now have over 155, 000 kms on my motor and it still runs great.
Old 02-04-2008, 10:25 AM
FuriouS's Avatar
You dont need synthetic on a 2.2, but its obviously a better oil.
It wont give you any performance gains. except your wallet will be lighter, so you might go a bit faster.
Old 02-04-2008, 10:36 AM
68nova200's Avatar
i noticed that it ran a heck of alot smoother. it was like my car was thanking me for changing. i also noticed more pull at higher RPM's
Old 02-04-2008, 11:20 AM
css9450's Avatar
Originally Posted by cobalt_driver
cudn't have said it better. i've been running with synthetic since i believe 3k on the car. What u'll gain is smoother ride...
It helps your suspension too? I can see it might help with the "butt dyno", otherwise, no.
...and ur car will die with like 298,000 on it.
I hope not! I had 318,000 miles on the last new car I bought before some kid totaled it. I'd still be driving it otherwise.
Old 02-04-2008, 06:58 PM
07BluBalt's Avatar
im sure what he meant by smooth ride is that of engine smoothness. just feels better under the hood.
Old 02-04-2008, 07:39 PM
im sorry but i refuse to believe that there is any possible way to tell difference from changing your oil. im not tryin to start anything but how can you feel a difference betwen oil. thats like saying your car fells faster because you washed it. less dirt=less drag. i always assumed the difference in convetional and synthetic is prolonged engine life. not more hp. untill i see evidence of a before and after i have to say i dont believe it at all....
not tryin to be a dick, just my opinion guys....
Old 02-04-2008, 08:42 PM
SpeedJunkies07LS's Avatar
i notice a big difference from going from castrol to mobile 1 i took the dealership oil outa the car an replaced it with mobile 1 the second 3000 miles and from changin to mobile 1 i noticed a decent boost in how my car acts i dunno if anyone elses car has had the same reaction or not
Old 02-04-2008, 09:21 PM
jbenso4's Avatar
synthetic is def worth it
Old 02-04-2008, 09:24 PM
BigTizzle903's Avatar
really no hp improvements. but the engine runs smoother.
Old 02-04-2008, 10:10 PM
randizzle's Avatar
seriously how many people are really gonna think they can feel a difference when they switch oils. there MIGHT be a difference of one horsepower. you will feel NO difference. you MAY have better longevity because of less thermal breakdown and better lubrication. that is all.
Quick Reply: Synthetic Oil for LS
