Theory... Hondas do it.
Old 02-11-2008, 09:09 PM
tru2nrtt777's Avatar
Hondas blocks and heads are interchangable hence why you can take a D15 block and throw a D16a head on it, or take a b18 and throw a V-tec head on it. In theory cant you take a 2.2 and throw a 2.4 VVT head on it? Would you need a 2.4 PCM? Would it even run?
Old 02-11-2008, 09:13 PM
BigTizzle903's Avatar
idk. good question. it wood be sweet if u could.
cobalt_addict's Avatar
i am sure it would physicaly fit.. but tuning it and getting it to run would be near impossible i think
steddy2112's Avatar
Why not wait til the le8 comes out???
The problem would be sensors...it would be a headache
Old 02-11-2008, 09:16 PM
Darkmanx's Avatar
Lemmy know how it turns out.
Old 02-11-2008, 10:13 PM
Shiot, I dont have the money to test this theory, I barely have the money for the front bumper I need to replace.
Old 02-11-2008, 10:15 PM
eurochevy's Avatar
Originally Posted by tru2nrtt777
Hondas
well theres ur problem
Old 02-12-2008, 08:20 AM
Kwin's Avatar
^ haha
Old 02-12-2008, 08:21 AM
Omega_5's Avatar
You would need the 2.4 PCM, as the 2.2 PCM lacks the VVT controlling capabilities.
Old 02-12-2008, 07:37 PM
even with the 2.4 pcm the car probly wouldn't run. like said earlier you would have problems with sensors and such
Old 02-12-2008, 08:53 PM
BLKLS's Avatar
if you swapped the harness, ecm, and changed the head i think it would work but you may need to change the insturment cluster too, and you might still need to program the ecm to the bcm i don't know how these cars are set up. i'm pretty sure that the block are from the same cast so all the sensor in it should be the same.
Old 02-12-2008, 08:55 PM
Raven SS's Avatar
its not that simple in hondas either..u dont just swap heads and call it good..but they have had the experiance in doing it and no one in the cobalt comunity goes that route
Old 02-12-2008, 08:58 PM
joeworkstoohard's Avatar
it's easier to change the block than everything else.
for example, i helped install a 7a-fe bock into an MR2 that had a 4a-ge originally.
that gave us a 1.8 litre rather than a 1.6.
sooo, if you had a 2.4 and wanted a 2.2 block, i guess you could... but why?
conversely, you MAY be able to put the 2.4 block under the 2.2 head and gain some power, but the tuning isn't there.
Old 02-13-2008, 04:16 PM
My buddy is a Honda Guru and we were talking about his k20 block/k24 head 6 speed CRX which got me thinking about that.
Old 02-13-2008, 04:17 PM
Raven SS's Avatar
u mean k20 head and k24 block..??
Old 02-13-2008, 04:51 PM
Sure, I dont know **** bout Hondas. I know it was some combo like that. I remember K20 and K24 were mentioned to be in it and one came from a RSX...
Old 02-13-2008, 04:52 PM
Raven SS's Avatar
lol i wasnt calling u out...but for the most part people go with the bigger block..
Old 02-13-2008, 04:57 PM
No problem man, I dont have a big e-dick, I can admit to being jack of all trades, master of nothing.
Old 02-13-2008, 05:01 PM
Raven SS's Avatar
lol i hear ya..im a jack of about 7 trades..and still havent mastered any
Old 02-13-2008, 05:06 PM
yeah, i know just enough to F-ck something up. LMAO
Old 02-13-2008, 05:41 PM
IonNinja's Avatar
i'm sure it can be done, Hondas have alot more backing from shops and stuff though so they can afford to have someone try it...
2.2VVT, yeah!
Old 02-13-2008, 07:32 PM
pg318's Avatar
2.2VVT, yeah!
Next year it'll be a standard build, presumably the Cobalt will get it. http://www.theautochannel.com/news/2...06/076896.html
Old 02-13-2008, 08:02 PM
Great now the question is if there will be a Hondata-esque pcm for Chevy...
Old 02-13-2008, 08:08 PM
switch the head, the ecm, the harness, and the instrument cluster? it might actually work if you do all of that.. who knows, somebody needs to try!
Old 02-13-2008, 08:13 PM
RaineMan's Avatar
There is a guy I know of with a LSJ head on the 2.4 block... call it a LSJ stroker...
Quick Reply: Theory... Hondas do it.
