thoughts?
thoughts?
i've been debating on ideas to be able to tune, going back and forth between a full out engine swap and megasquirt. the other night though i started wondering if it'd be possible to just replace the head and pcm. anyone know anything about this? would it be a direct bolt on plus tune or would more be required to make it work other then probably having to repin connectors and whatnot.
Bit pricy. If I swap the head or engine I'd probably try to get it out of a junkyard and rebuild it. I know there's a lot of interchangeability between the lsj and l61 which is why I was wondering if I could just bolt an lsj head on and repin the PCM with it and be good to tune then
kimmef
05-03-2016 01:05 PM
