Throttle Body - Options
Old 09-06-2007, 01:36 PM
blktrax's Avatar
Originally Posted by NJHK
True but they still go by the same theory...so I don't think it's cause you have a 07.
I understand why you say this, but youre not seeing all the pecies to the puzzle. What I'm working on is a solution that any cobalt can "Bolt On". Not everone is capable of soldering and putting on weather shieled cable ends, and if they eff them up... Well that engine harness isn't cheap, nither are the connectors.
Old 09-06-2007, 01:49 PM
NJHK's Avatar
Originally Posted by sick06cobalt
lol thanks adam.. yeah i didnt read it really.. but thanks man.. i got ya,... heres some rep fo you
You're welcome
w0rd.
Old 09-06-2007, 02:50 PM
IonNinja's Avatar
I thought the UK guys were using 2.0 TB's??
I could've sworn some guy on here was saying that...
Old 09-06-2007, 04:25 PM
slindborg's Avatar
I know someone running a 2.0 TB but its not a direct fit.
the 2.4 is electrically the same as the 2.2 ETB so no issues there.
Old 09-06-2007, 06:15 PM
HunterKiller89's Avatar
Exactly. It didn't make sense why a MAF would cause the limp code.
I would imagine the MAP sensor would throw a code if there was a leak post MAF because it's having trouble building pressure and with MAP sensors, it uses manifold pressure to help determine engine load and other fueling factors.
it will go into limp home mode, but for a different reason. your engine will get more air at idle with a larger TB, causing the ecu to flow a bit more fuel to help maintain a 14.7:1 idle afr. this however, creates more power at idle, causing the car to idle above 100RPMs, which tells the ecu that there is an air leak
^^posted this in both TB threads
Old 09-06-2007, 06:53 PM
NJHK's Avatar
Look up what a IAC does.
When you're at idle, your throttle plate is closed.
Old 09-06-2007, 07:10 PM
hmm...i recall this is what CED stated when they were explaining why they couldnt sell a kit with the 2.4mani AND the 2.4 TB...now im confused
Old 09-06-2007, 07:12 PM
NJHK's Avatar
Hit me up on AIM.
DarrenGC
12-24-2021 01:55 PM
10-13-2015 09:32 PM
SSLOW06
10-01-2015 07:21 PM
Adiaz1ss
09-26-2015 11:51 PM
09-26-2015 06:44 PM
Quick Reply: Throttle Body - Options
