Throttle body spacer??
Not if you're going to a larger t/b with larger butterfly. A spacer is wholly necessary to get the ls4 t/b to work with the 2.0 s/c inlet. As for spacers for the 2.2 I don't know, maybe nate from smoothflow could fabricate one for you or you can ask rebel or c/a if their spacers fit the 2.0. Again...a spacer is useless unless you are going for a bigger t/b or spraying nos or meth.
I've done a K&N cai,(2006 LT)and thought that the spacer would help as well....not looking at doin nos or meth as of yet...though a bigger t/b would be a good idea...... Nate from smoothflow? who and where is that? lol
hmmm... might do that...i just dont want to drill into my intake so i can sell it for more when the time comes.
umrdyldo.....thanks for the heads up. ya...not looking at doin nitrouse any time soon soo.....Totally way off topic though...do you know of anyone having problems with their tail lights getting moisture in them? i have the second set of lights from the GM and they are getting moisure in them again. .....problem with install? or is this a manufacturer defect?
Throttle body spacers will give you actually a good increase in airflow. If you have ever seen the AIRAID spacers they have grooves cut into the spacer to make the air swirl resulting in sucking more air. I used to have one on my 03 dodge ram truck. It worked excellent. However they dont make one for the 2.2 throttle body yet.
