Time to build for more boost...
Old 09-10-2012, 07:54 PM
  #51
TurboTechRacing's Avatar
Originally Posted by 06_ion2
How hard are LSD's to install and uninstall in the f23? If I buy one i dont want my next trans to take a dump at 20k again. Then id have to swap it into another junkyard 5 speed. 2nd gear is almost out and 3rd is all the way out currently. Is there a better option that i could use. I wouldnt mind spending 2k if it lasts.
If you can replace a clutch you should be able to handle the task. I would rate it on the same level of difficulty.
Old 09-10-2012, 08:10 PM
  #52
06_ion2's Avatar
I pay someone to do that. Not worth my time.
Old 09-10-2012, 08:11 PM
  #53
lol! j.k.
  #54
klutch814's Avatar
clutch is easy to do... so fairly easy im assuming
Old 09-11-2012, 01:17 PM
  #55
rcarr0327's Avatar
yea i would spend like the 220 bucks and get a team green lsd insert
Old 09-11-2012, 01:37 PM
  #56
klutch814's Avatar
say what? how much is it? lol
Old 09-12-2012, 09:58 AM
  #57
rcarr0327's Avatar
price is $255 shipped to the US, $270 to Canada.
To order, either email this email address, or Paypal the same email address, making sure to put car and trans info in the comments section.
Brian
TeamGREENPerformance
teamgreenperformance@live.com
Old 09-12-2012, 08:36 PM
  #58
klutch814's Avatar
**** ill look itnto it. on another hand:
more parts came. got my water pump and injector insulators at work today. rod bearings came.. although only one set for one rod... so i have to re order them. hopefully getting my pistons and rods on monday.
Old 09-12-2012, 11:19 PM
  #59
Brags's Avatar
A cheaper option, that works fairly well is the Team Green LSD inserts. Fraction of the price of full replacement units.
I agree with you an this one, Mine works great, really helps. I think I paid 200 for unit and 200 for install. Well worth it!!
Old 09-13-2012, 01:05 PM
  #60
stenguyen1's Avatar
make sure the surfaces of the bearings aren't scratched or anything. i bought a pair and had to switch them out like 3 times before i had a clean set.
Old 09-13-2012, 05:17 PM
  #61
klutch814's Avatar
im just gonna order new ones
Old 09-13-2012, 06:03 PM
  #62
stenguyen1's Avatar
i know you buying new ones. i'm saying to look at the surface of them to make sure they aren't scratched cuz i bought new ones and they were all scrateched up. so i had to exchange them.
Old 09-13-2012, 06:11 PM
  #63
klutch814's Avatar
ok man ill be sure to look
Old 09-16-2012, 12:49 AM
  #64
klutch814's Avatar
come monday ill be ordering wiesco 10:1 pistons, eagle rods, rings, cap bolts, and clevite rod bearings. then all that is left is head stuff. talked to a machine shop and for $100 ill get the head pressure tested, hot tanked, valves/springs installed, and shaved if its warped. all done within 2-3 days. this build should be cake.
Old 09-16-2012, 09:50 AM
  #65
conerboner's Avatar
in for pics of build have fun with it and take your time. You'll love the high boost
Old 09-16-2012, 10:20 AM
  #66
klutch814's Avatar
i hope i do man! after that i need to order: head studs, head gasket, valves, springs and an intake mani if i have enough. then ill buy external wastegate, 80's, and the turbo
Old 09-19-2012, 08:42 PM
  #67
klutch814's Avatar
alot going on lately. turbo manifold got lost in the mail and kid backed out on my curent kit. so i will be rebuilding then bigger turbo in the near future unless someone buys my kit.
Old 09-24-2012, 08:43 PM
  #68
klutch814's Avatar
a little update: I'll be running 22psi on the k04 once i get the engine built. no one wants my current kit right now so ill collect parts over winter for the bigger turbo. plus i need to learn how to handle another 100 whp first. i should have everything for the build withing 3 weeks then ill plan a date. build shouldn't take long. tear down will be done in a n night then my head gets sent to get everything put in and checked. while thats being down ill install the pistons and misc. oem parts. once the head comes back (2-3 days) ill put it all back together and get a tune from james. getting excited especially now that its getting colder my car pulls like a **** in the mornings. i love it lol. now to get reliability done.
Old 09-26-2012, 10:19 PM
  #69
rcarr0327's Avatar
i might be selling my zzp stage 2 kit if you want it, just need a bigger a spring for more boost?
Old 09-26-2012, 10:28 PM
  #70
klutch814's Avatar
pm me. id just want the turbo manifold wastegate lines and down pipe
Old 09-27-2012, 09:26 PM
  #71
klutch814's Avatar
pistons, rods, bearings ordered 9:1 compression. still have some left...moar parts!!!bqdkjbfsd nfvb sdjbjrfbjhwrsdjkln haha.
Old 09-28-2012, 01:23 PM
  #72
rcarr0327's Avatar
is 9:1 the same as lnf?
Old 09-28-2012, 05:33 PM
  #73
klutch814's Avatar
thats a good question..
Old 09-29-2012, 03:54 PM
  #74
klutch814's Avatar
updated op...zzp or supertech valve springs?
Old 09-30-2012, 02:11 PM
  #75
rcarr0327's Avatar
zzp is 82# and with titanium retainers still cheaper. i dont know about them much tho
Quick Reply: Time to build for more boost...
