Time to build for more boost...
Old 10-23-2012, 09:46 PM
  #101
klutch814's Avatar
got a big step done today. started by plastigauging all rod bearings. checked out A-OK. then installed pistons for the final time. checked ring gap on one and it was fine. easy but time consuming. put new water pump and chain in. was a real bitch. need to order a new lower tensionor at work tommrrow and the front cover can go back on. cleaned oil pan and front cover. tommrrows plans after work include cleaning block top/sides, put oil pan back on, and if the head is done which it should be mount the cames mani fold and turbo on it and drop it in. then it SHOULD be easy sailing there on out.
Old 10-26-2012, 06:39 AM
  #102
klutch814's Avatar
got work done last night how ever had problems. got the head it looked brand new i was very pleased.. got the manifold and turbo mounted and did a test fit and we were good. noticed my manifold is cracked but nothing i could do. got the head on head studs tourqed. went to put the cams in and snapped two cam cap bolts. im very afraid to do this now but we will see. in the meen time got the intake mani on injectors and fuel rail in down pipe on spark plugs in.
i have way more pics that didnt load ill post later
05-28-2022 03:47 AM
Fearedbynone
04-14-2016 03:25 AM
hacadacalopolis
10-28-2015 06:09 PM
biniecki
10-25-2015 02:23 PM
10-13-2015 09:32 PM
Quick Reply: Time to build for more boost...
