Torque setting for head E-torx bolt?
I have arp head studs and know the torque on them but what about the e-torx bolts by the cam gears?any one know?
http://www.*******************/forum...e-torque-specs
everything you will ever need right here ^^^^ whoops guess im not aloud to reference another forum
Last edited by yamaha288; 08-16-2013 at 05:15 PM. Reason: forum referencing not aloud
^^^correct. tighten the arp studs to the first of the three (?) recommended torque pulls, and then tighten the small torx to spec, then finish with the studs. The stock procedure is tighten head bolts, then torx then continue to 155 degrees on the head bolts. The stock head bolts are TTY
