Total Horsepower.....?
I was looking at a post that says i want 200 n/a and im thinking to myself if you had a short ram intake, exhaust, headers, 2.4 swap, stage 1 or 2 cams, forged pistons, nicer plugs wouldnt you be pushing 200 and a lil greater and if you put like a 55 shot on it but then again I guess hats f/i but yeah add up the other mods and let me know what you think you'll get thanx guys
you do not need "forged" pistons for a road car unless your putting out over 600 horsepower and a heavy shot of nitrous you dont need forged anything... way to expensive for road applications, id go intake exhuast stage kit, cams, wedged or concave shaped pistons pending on raising or lowering compression, ported combustion chamber, valve job. ull be haulin ass then
shortram because I have a sai ( so aimd ebating can I put headers on and can i do the intake manifold swap with out any obstructions in the process my goal is like others is to get 200 n/a and with a nice nos shot beat some ss's no offense ..im a kid and only could afford a new ls
With all the mods you listed, i would be suprised if you saw more than 165WHP.
Forged pistons are not "way to expensive" for road applications, ypoiu can pick up quality pistons for the ECO around $400 if you look around and you'd be hard pressed to spend more than $700 for CUSTOM FORGED pistons. Not to mention good luck trying to find an aftermarket cast piston in anything other than stock(and you probably wont even find that)
If you replace pistons in an ECO, you put in forged ones. As far as the 600hp AND a heavy nitrous hit, well aty that point youd need a new crank, rods, pistons, and cylinder liners.
And why on earth would you put LOWER compression pistons in an NA build?
To go beyond 200crank hp and get 200 to the wheels which is what the other thread is about, youll need higher compression pistons and head work.
This is just inaccurate. L61 pistons are known to fail in the 240-270hp range.
maybe the guy got confused and was reading about a f/i car lowering compression and thought it was n/a
Last edited by EXsoccer1921; 09-19-2008 at 12:06 PM. Reason: Automerged Doublepost
With those mods, yeah youre likely to get to 200 CRANK hp with a tune.
well. to the OP. if you want 200 on a 2.2L. your gonna need some engine work. plain and simple. so for the money youre gonna spend to pull most of the engine and the work thats gonna be done to it. why not shoot for higher than 200?? youre definitely gonna need new pistons with about an 11:1 ratio. ported head, i'ld go with comp stage2 cams, intake, full exhaust, larger injectors, awesome tune. and if you want you can replace the sleeves and run a 75 shot
I'm too JDM for you
lower compression and stuffing more air will give you more torque..... hello and ok ill with the cast piston ill just call up and ******* manufactureing and tell them to build me one..... dont get stuck in aftermarket scams buddy you can do **** cheap you rlly dont need forged.... yes its durable and strong but for 200hp is kinda rediculious
i know how it works buddy..... i go to auto tech school. but lowering compressions and stuffing more air will give you more torque.... of course your going to have to make a shorter stoke for this to work but it will be very rewarding maybe not a good idea for a 2.2 cuz it has no forced induction but he was saying he was thinking about it....it would be a good idea raiseing compression give you more high end horsepower. so don't call me an idiot when i go to school everyday for this ****.
You will pay the same if not more for a cast hyper or hypo piston than you will for a forged set just because of economy of scale.
Reliability is another issue, you are changing out the cast stockers, why you wouldn't replace them with something more reliable is mind boggling.
why bother with this when u can go turbo for probly the same price if not cheaper if you make your own kit... just doesnt seem to worth it to me to go through the work to make the 2.2l over 200 to the wheels but to each their own i guess
I'm too JDM for you
i know how it works buddy..... i go to auto tech school. but lowering compressions and stuffing more air will give you more torque.... maybe not a good idea for a 2.2 cuz it has no forced induction but he was saying he was thinking about it....it would be a good idea raiseing compression give you more high end horsepower. so don't call me an idiot when i know how it works better than you do. i go to school everyday for this ****.
Not true. Higher compression equates to higher cylinder pressure and creates more torque. Stuffing more air in is a function of the top end, not the bottom.
so do i buddy, i go to UTI. and i hope you have noticed that the hahn turbocharged lsj made 440whp and 290tq with low compression pistons(like 8 to 1) while paul in ny made 420+whp and 365 torque if i remember correctly. your wrong, lower compression does not give more torque. low compression pistons on a NA build is retarded
but dont get me wrong, i love my 2.2
wen did i say anything about BTC? compression kinda occurs at TDC we all know this.... fordged is just alot more expensive in my mind... cast steel will do the same thing.. were not building a ******* race car here.... if your running strickly strip then go for it go forged.... **** breaks the same anyways... have you seen an engine blow up.... its all the same. were talking about a daily driven car. 2.2 liter not much to do on the performance side in the first place.
Nobody said anything about BTC? You stated lower compression and stuff more air in. We are talking about an NA engine, good luck getting much higher air pressure than ambient. Lower compression pistons do not stuff more air in, thats a function of the top end of the engine.
Cast steel pistons? Pistons are made from alluminum.
Again you are changing the pistons as it is, forged units are available for the same if not less than a cast set, other than piston slap (I have run forged pistons in multiple ecotecs without slap) I fail to see any benefit of staying with a cast hyper piston.
