Tsudo exhaust issue
Old 08-13-2010, 04:10 PM
eutechnyx's Avatar
Tsudo exhaust issue
I just installed mine using all factory hangers and it literally rests on the bumper and makes alot of noise when going over bumps and braking because of it hitting the bumper. What have people done about this? any special hangers for the back or something?
Old 08-13-2010, 04:20 PM
coopercharge's Avatar
When I put mine in I got some of the drop down exhaust hangers for trucks that was my remedy!
Old 08-13-2010, 07:10 PM
eutechnyx's Avatar
Do u have a link to what they looked like? did u drop the entire thing down or just the back?
bump...this is annoying lol
Old 08-13-2010, 07:42 PM
arman14's Avatar
Get some bigger hangers at Autozone or O'reilly.
Old 08-13-2010, 07:48 PM
warrenb213's Avatar
your going to want to do a combo if you want it to look perfect.
if you simply do the hangers, u still run the risk of the HOT exhaust actually discoloring and melting your clear/paint.
you'll also want to have a new tip put on, so that it sticks a lil further out, the lip of the tip should be essentially flush with the further extent of the rear bumper.
if your exhaust, under heat, somewhat torque's around a bit like mine did, you'll wanna have a high quality steel plate welded on between two points on the exhaust.
with the hangers, tip, and plate, the tsudo will have no issues. still costing less than the top brands.....
Old 08-13-2010, 07:58 PM
Magz_rule's Avatar
Just put my tsudo exhaust on a couple days ago. Went to autozone and bought 2 longer hangers for 5 bucks each and all is good. Takes 30 seconds to swap them.
Old 08-13-2010, 09:33 PM
HyperMuffin's Avatar
Happened to me to. Except I am to lazy and it just melted my bumper to a custom arch lol. Makes my bumper a little black as well haha.
Old 08-14-2010, 12:36 AM
eutechnyx's Avatar
Not really wanting to do all that work for my exhaust,I am sure thats the best way but just swapping out hangers is what im going to try first,Just gets annoying hearing the metal on metal from the exhaust vibrating against the metal hanger location. Magz did u find rubber hangers or those cheap metal ones?
Old 08-14-2010, 05:19 PM
olivecj's Avatar
I got longer rubber hangers at napa for like 10 bucks and the exhaust was fine after that. The ratling and buzzing also went away.
Old 08-14-2010, 05:37 PM
Magz_rule's Avatar
Longer rubber ones, not metal. Worked perfect.
Old 08-15-2010, 07:31 PM
eutechnyx's Avatar
Gotcha...anyone else have issues of the exhaust system hanging down alot in the center of the car? My car is lowered on sportlines and with 3 ppl in the car it scrapes the ground...also from a side look u can see the pipe hanging down,I can get a pic real quick.
Old 08-15-2010, 07:33 PM
arman14's Avatar
I have the same problem with mine.
Let me know if you find a solution.
Old 08-15-2010, 08:08 PM
Mine is the same way and I don't know if you can fix it.
Old 08-15-2010, 08:13 PM
eutechnyx's Avatar
Only thing I could think of is weld a hanger location right there where th epipe hangs and try to hang it up a lil higher,but idk.
Old 08-15-2010, 08:35 PM
warrenb213's Avatar
damn, mine doesn't really appear to hang quite as low as ya'lls.....
Old 08-15-2010, 10:39 PM
eutechnyx's Avatar
Thats close to how mine is,but my car is lowered...after looking my pipe does look lower =\ maybe its the old hangers?
Old 08-16-2010, 07:09 PM
Magz_rule's Avatar
Mine is fine as well
Old 08-16-2010, 07:17 PM
arman14's Avatar
I'll get a pic of mine later, It sits really low.
Old 08-16-2010, 07:55 PM
eutechnyx's Avatar
This issue really sucks...IDK why it sits so low on my car,it really makes me want to get rid of it,from a low side view it looks like it was installed incorrectly lol.
Old 08-16-2010, 07:59 PM
warrenb213's Avatar
welllll, ya know, i did offer my advice on how to get it correct. just seems like nobody here was interested.....cause it was doing more than just aftermarket exhaust hangers from vatozone.
Old 08-16-2010, 08:03 PM
blackbolt89's Avatar
mine is the same as eutechnyx. it bothers me and that is the reason why im still stock height on steelies. i dont like the idea of scraping. i already scrape my exhaust on sharp angled driveways and speed bumps. lol
Old 08-17-2010, 08:17 AM
Brenden Griswold's Avatar
then why did you post this? I installed my Tsudo exhaust yesterday and I bent the stock hangers a little bit to give some clearance of the bumper. The exhaust hangers are the next best thing, and you dont have to jack the car up really. Its easy, takes like 5 minutes
Old 08-17-2010, 08:37 AM
I had to reweld the hangars it took me about an hour. any muffler shop should be able to do it if you cant.
Old 08-17-2010, 11:09 AM
eutechnyx's Avatar
Well Ive got so many other projects going on right now,dont really have time to put that much time into a little exhaust on my daily lol Ive got a bodied blazer on 22's im working on,a blazer on 24's and then a nova...too much on my plate right now haha. but like I said im sure its the best way.
Ill give that a try,thanks.
Old 08-17-2010, 11:14 AM
autozone has exhaust hangers that you just bolt into any spot under the car, and then you can adjust the height of the hanger itself. . . mine does hang low in the middle a little bit too. I think I might try bending it up a little bit
Quick Reply: Tsudo exhaust issue
