turbo options
turbo options
I have been looking into turbo options lately
I am finished with the body on my car, the interior, and my suspension is almost finished.
Motor is next on my kill list
Im not wanting to go huge and put out big numbers and run low 1/4 mile times.
I have never built a turbo car. This will be a learning experience for me.
If later i want to go bigger and faster ill buy a faster car lol
for now this is what i have looked into a simple t3 turbo setup on low boost so i can run a stock motor.
How much boost/hp would my 2.2 be safe up to?
Turbonetics T3 & T3/T4 Turbo Turbochargers: T3/T04B, T3/T04E, 50, 60
this is the manifold i have looked into.
What kind of exhaust set up would i need to run off a turbo. can i do a zzp dp? stock?
What kind of turbo kit would be good.
I have seen some on ebay for around 1000 w/ external wastgate all it would need is oil feed&return lines and a bov. good idea or no????
Also would a 2.4 intake manifold be able to work and a 2.2 or would i need a different manifold? or could a run my plastic one? << that dont seam like a good idea to me tho
comments
comments
comments
comments
Then get a properly sized turbo for your power goals.
Get a proper dyno tune. No tune is safer.
And dont get power hungry and turn the boost up later down the line.
1 Post
If you wanted to drop the cash for it I would go with the ZZP turbo kit. However you do need your own tune. But 6 psi will be safe on the stock motor you could probably squeeze 8 if you really wanted to. And you will break 200hp lol.
its a used kit my buddy has. Its all the pluming, front mount, oil feed and return lines, bov. I would need a turbo, turbo manifold, intake manifold, exhaust dp, and tune i think is all
importkiller
09-30-2015 07:18 PM
