Turbo Question
Turbo Question
If you have a DC exhaust, and later decide you wat the turbo, will the dc exhaust be compatible with the turbo system? or would i have to get a higher flo exhaust
Depends on what size turbo and what your power goals are. i put a 3" exhaust on because i knew i was going for some large power. a 2.25" exhaust will do just fine with a turbo later on. You will max your engine internals out before you max the 2.25" exhaust out.
