Turbo Tech Braking Products
i am looking at turbo tech racings website and i found some rotors and brake pads. has anybody have reccomndations on what rotors to get?? i have heard really good things about the hawk brake pads so i was looking at geting those. and do the pads come as one pad or two for either side??
usually when you buy break pads you buy either the front or rear set and they come with 4 pads in all in one set so if you bought front and back breaks you should have 8 pads in all 2 per tire... not tryin to sound like an ass just lettin ya know. but as far as buying rotors im not to sure i know there is like slotted, drilled and i think maybe even slotted and drilled but i dont know which is better then the other.
thy will send you pads for both front wheels, thats it, judging form your pics u have rear drum, i recommend the powerslot rotors, you dont need drilled and slotted, they arent beneficial, you are losing friction from the holes on the rotors and the slots, but slots alone can help with cooling w/out sacrificing as much of your brake pads bite on your rotor...but if you want looks over performance than i suggest the EBC rotors
