Turbo Tech Racing Releases Transmission Bushing Kits!
I'm thinking about this on my 2.2, but I'm worried about the vibrations. I'd love to have the better power delivery, but I don't want noticeable vibes at idle. Is the install easy enough that if I don't like them I can just remove them and go back to stock?
The installation is easy but going back to stock would not be an easy task. The stock bushings get pretty messed up when removing them to put the new ones in. Seriously tho the vibes are only bad at idle when the car is cold. Once it warms up a bit they tend to get a little softer and is not really noticeable. Also if you listen to the radio at about a medium level the radio will drown it out as well. Overall the vibes are easy to get use to and with the advantages you get from the bushings the added noise is worth it.
09BlkCrusader
09-09-2015 04:47 PM
